| bmtrnavsky |
Sep 1 2010, 12:23 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
I was driving home last night and my low beam headlights stopped working. High beams come on normal and all the other lights work. Fuses are all good. Ideas? (IMG:style_emoticons/default/confused24.gif)
| VaccaRabite |
Sep 1 2010, 06:36 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,882 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
1) unhook the battery.
2) drop the fuse panel in cabin of the car. 3) Make sure the low beam fuse has not blown (fuses 3 and 4) 4) look for a rectangular relay that is held on the fuse panel with a little metal clip, and not the rubber bullet like the other relays. The relay in question will have leads going to fuse 1 and 2 (high beams - white wire) and fuse 3 and 4 (low beams, yellow wire). In the relay, pin 56a is the low beam pin, and will have a yellow wire. Pin F is the high beam pin, and will have a white wire attached to it. 5) replace it. Some beetles use a different relay looking, but the wire diagram on it is the same and it works in place of the stock 914 part. Confirm that you don't have any wires grounding out and plug back in the battery. You will now be able to test the headlights. If they work, unplug the battery again and replace the fuse panel. Zach |
| bmtrnavsky |
Sep 2 2010, 12:52 AM
1) unhook the battery. 2) drop the fuse panel in cabin of the car. 3) Make sure the low beam fuse has not blown (fuses 3 and 4) 4) look for a rectangular relay that is held on the fuse panel with a little metal clip, and not the rubber bullet like the other relays. The relay in question will have leads going to fuse 1 and 2 (high beams - white wire) and fuse 3 and 4 (low beams, yellow wire). In the relay, pin 56a is the low beam pin, and will have a yellow wire. Pin F is the high beam pin, and will have a white wire attached to it. 5) replace it. Some beetles use a different relay looking, but the wire diagram on it is the same and it works in place of the stock 914 part. Confirm that you don't have any wires grounding out and plug back in the battery. You will now be able to test the headlights. If they work, unplug the battery again and replace the fuse panel. Zach Thanks! |
| windforfun |
Sep 2 2010, 11:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,099 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
1) unhook the battery. 2) drop the fuse panel in cabin of the car. 3) Make sure the low beam fuse has not blown (fuses 3 and 4) 4) look for a rectangular relay that is held on the fuse panel with a little metal clip, and not the rubber bullet like the other relays. The relay in question will have leads going to fuse 1 and 2 (high beams - white wire) and fuse 3 and 4 (low beams, yellow wire). In the relay, pin 56a is the low beam pin, and will have a yellow wire. Pin F is the high beam pin, and will have a white wire attached to it. 5) replace it. Some beetles use a different relay looking, but the wire diagram on it is the same and it works in place of the stock 914 part. Confirm that you don't have any wires grounding out and plug back in the battery. You will now be able to test the headlights. If they work, unplug the battery again and replace the fuse panel. Zach Thanks! The generous disconnection of the battery is superb advice when working on old electrical systems. |
bmtrnavsky Low beam headlights not working. Sep 1 2010, 12:23 PM
bmtrnavsky
I was driving home last night and my low beam hea... Sep 1 2010, 12:28 PM
vsg914 Did you try rolling the fuse in it holder? Sep 1 2010, 12:30 PM
dr914@autoatlanta.com Hi Low beam relay has failed. Typical
I was d... Sep 1 2010, 12:38 PM
bmtrnavsky
I was ... Sep 1 2010, 12:40 PM
anderssj I had this problem about 5 years ago on my 72.
If... Sep 1 2010, 12:48 PM
bmtrnavsky
I... Sep 1 2010, 04:44 PM
avidfanjpl Relay is behind the fuse panel. 2 screws or bolts ... Sep 1 2010, 05:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:27 AM |
