are dashs the same for all years |
crxnug |
Sep 4 2010, 07:40 PM
Member Group: Members Posts: 81 Joined: 20-December 07 From: ontario, canada Member No.: 8,489 |
are there any differences in dashs the the years, if so does someone have a pic or info on how to tell the differences,
Dr Evil |
Sep 4 2010, 09:31 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
The "dashes" are all the same if you are only referring to the top cap. The vents change the lower dash or the vinyl piece that covered the area between the dash cap and the windshield (IMG:style_emoticons/default/wink.gif)
realred914 |
Sep 4 2010, 09:40 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
The "dashes" are all the same if you are only referring to the top cap. The vents change the lower dash or the vinyl piece that covered the area between the dash cap and the windshield (IMG:style_emoticons/default/wink.gif) no, the dash top was different also when the side vents appeard, minor side detail, if you put a late dash on an early cars lower dash assemble, you cant open the early bigger glove box door all the way, it will hit the later dash top. in dash top i refer to the big foam/vinyl piece that forms the hood over the instruments and runs the width of the car. this can be an issue when foks replace cracked dash tops, you need to be specifc about the style not all folks are even aware of the difference. just been thru this issue with a friends 914, so that how I learned yes early cars had an extra windshield vent. in the middle , however it was not mounted on the foam/vinyl dash top, but rather on the metal dash structure that is forward of the dash top. hope that makes sense |
Lo-Fi Version | Time is now: 9th June 2024 - 08:33 PM |
