| thelogo |
Sep 9 2010, 09:40 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
(IMG:style_emoticons/default/piratenanner.gif) Is this the so called 5k engine , ????? (IMG:style_emoticons/default/biggrin.gif) or what would this build cost -minus labor
this engine has been on evil bay . at least once , auction ran out with no bids . buyer is asking , 5500. buy it now . it's in riverside . local pickup for me / i also have a truck Is this a good deal or will future 2.0 2056c/ far exceed this build. I know as far as cyclinder heads . jake has actual new heads . but other then that what advantage's would a new build have to this . And price wize , is this as good as it get's or would using my current 1/7 engine to build a 2056 be less or as expensive or more . if also built to 2056c with my stock d'jet . also consider ; i'm not a engine builder (IMG:style_emoticons/default/agree.gif) I bought a 5k car about a year ago , that runs like a champ . looks good and other then new batt . have never had an issue with . but bolt this in and i'm sure i'd be loving it even more ? along with a new exh. (IMG:style_emoticons/default/sheeplove.gif) O and oil accumlators . ? are they used on high performance production cars (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/welder.gif) Attached image(s)
| sean_v8_914 |
Sep 10 2010, 07:45 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
I dont know how guys can build something GOOD that cheaply. it takes me days just to measure everythng. it takes even longer to clean EVERYTHING. then add up just the machining costs.
balance pistons rods flywheel p-plate, align bore, decking, tap oil plugs measure heads, cc, deck height, pistons, cylinder bores, ring gaps, bearign clearances, valve geometry HEADS, rebuild, weld, machining, cores, valves, seats, guides, springs "The $5k Engine" is a long block. there is a therad about it and it is a good deal for known parts combo. a tru pro has measured and made sure everthing works together. read carefully. he explains alot http://www.914world.com/bbs2/index.php?showtopic=42456 |
thelogo 2.0 engine on ebay ? Gem ? or old tech already? Sep 9 2010, 09:40 AM
vsg914 No link? Too lazy to search ebay for something I d... Sep 9 2010, 09:54 AM
kg6dxn This message seems like jibrish. Can you please as... Sep 9 2010, 10:08 AM
RobW For a long term 914 motor and owner, you or someon... Sep 9 2010, 10:21 AM
thelogo that's my bad
... Sep 9 2010, 10:25 AM
kg6dxn It has a pretty paint job! Really can't te... Sep 9 2010, 10:36 AM
thelogo
It has a pretty paint job! Really can't t... Sep 9 2010, 01:02 PM
kg6dxn
It has a pretty paint job! Really can't ... Sep 9 2010, 01:14 PM
Spoke McMark is a smart guy and does good work. I would ... Sep 9 2010, 05:07 PM
DanT see here motor listing Sep 9 2010, 10:53 AM
Mark Henry Std Polished crank with .025 main and rod bearings... Sep 9 2010, 01:24 PM
Headrage Onion? Sep 9 2010, 05:40 PM
Vacca Rabite Someone here bought a 2.4 T4 that guy build and so... Sep 9 2010, 05:54 PM
thelogo
Someone here bought a 2.4 T4 that guy build and s... Sep 9 2010, 06:55 PM
Vacca Rabite
Someone here bought a 2.4 T4 that guy build and ... Sep 10 2010, 07:24 AM
avidfanjpl I know him.
Michael Schantz. Maybe 23 years old.
... Sep 9 2010, 09:36 PM
type11969 Grad student . . . his time is cheap, I know this.... Sep 10 2010, 10:04 AM
sean_v8_914 last thread asking about him had a few references ... Sep 10 2010, 10:49 AM
ripper911 So, if I rebuild my old engine myself and it runs.... Sep 10 2010, 05:28 PM
carr914 Making a couple hundred for pizza and beer as a g... Sep 11 2010, 06:15 AM
Dr Evil :agree: I have been the cheapest tranz rebuilder, ... Sep 11 2010, 11:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:35 AM |
