> Going to bring the car to the shop, I need some help
weird_looking_cactus
post Mar 19 2004, 04:05 PM
Cactus
Im getting very tired of trying to fix my car my self so I guess Im going to fork out the money and just pay someone to get it running for me. I can get it started by pouring a little bit of gas right into the throttle body but the car won't stay started. I had the car running on 2 pistions not to long ago and I have just replaced a fuel injecter after testing it and finding out it does not work. I have already put new spark plugs changed the oil and replaced the fuel lines but now it just won't stay going. If I press on the gas, once I get it to start it will ether die cause it gets fluided or it will jump up to a high rmp then drop like a door knob. The only place I can find that will work on my car is charging $70 a hour so what do I tell him to fix? Is it my timing or somthing else. My car is a 2.0 1975. Thanks
John2kx
post Mar 19 2004, 04:30 PM
Weird,
If you have given your best shot at getting car to run without positive results, I would give a pro a try. Give them a cap on what your willing to spend $$$$ wise, but from what I have experienced in the past, a good mechanic should have things figured out in less than a hour or two. To save time and money, you should attempt to find someone with 914 experience.
You may be in for less than $5.00 in parts and his time or need more expensive fuel injection parts. It's going to take a little time to figure it out........yours or his.
John
weird_looking_cactus   Going to bring the car to the shop   Mar 19 2004, 04:05 PM
vsg914   Sounds like a fuel delivery problem. If it starts,...   Mar 19 2004, 04:13 PM
weird_looking_cactus   Yep I have a manuel the place Im bringing to is a ...   Mar 19 2004, 04:21 PM
John2kx   Weird, If you have given your best shot at gettin...   Mar 19 2004, 04:30 PM
weird_looking_cactus   Well great I think I found my problem is I need a ...   Mar 19 2004, 04:51 PM
lagunero   Great that you may have found the problem but at t...   Mar 19 2004, 04:58 PM
vsg914   Cactus, all of sudden this sounds like the fuel in...   Mar 19 2004, 05:09 PM
weird_looking_cactus   Well now I know what the problem is I would like ...   Mar 19 2004, 05:10 PM
lapuwali   They have to be working from the first turn of the...   Mar 19 2004, 05:21 PM
lapuwali   Diz = Dizzy = Distributor, which you've alread...   Mar 19 2004, 05:22 PM
weird_looking_cactus   Ah thats what you mean about dizzy thanks on the f...   Mar 19 2004, 05:25 PM
vsg914   Ecu's almost never go out. What manual do you ...   Mar 19 2004, 05:26 PM
weird_looking_cactus   I have the haynes manuel I think I found what were...   Mar 19 2004, 05:46 PM
vsg914   was it plugged in?   Mar 19 2004, 05:48 PM
Jeff Bowlsby   Another thing that will prevent the fuel injectors...   Mar 19 2004, 05:52 PM
weird_looking_cactus   Well this is the best thing to happen to me so far...   Mar 19 2004, 06:16 PM
lapuwali   No, now you'll just have to worry about a lot ...   Mar 19 2004, 06:33 PM
vsg914   opps, another one lost to the dark side :o Too ba...   Mar 19 2004, 06:35 PM
nebreitling   i have to disagree on this one. even though carbs...   Mar 19 2004, 06:39 PM
GWN7   Haynes manual -chapter 3/ Ignition system, page 66...   Mar 19 2004, 06:55 PM
vsg914   Well, I honestly have to agree with both nebreitli...   Mar 19 2004, 06:59 PM
weird_looking_cactus   Thats the thing Im just sick and tired of messing ...   Mar 19 2004, 07:02 PM
vsg914   500-600? depends on what carbs. One carb? no!   Mar 19 2004, 07:12 PM
nebreitling   5-600 bucks for some decent shape twin carbs and l...   Mar 19 2004, 07:17 PM
vsg914   Curt. and You?   Mar 19 2004, 07:19 PM
nebreitling   Nathan nice to have a name on the avatar! ...   Mar 19 2004, 07:20 PM
nebreitling
- Lo-Fi Version Time is now: 11th July 2025 - 07:01 AM
