> fuel starvation while turning, it never freaking ends....
nebreitling
post Mar 19 2004, 05:06 PM
Member Emeritus
when i throw the car into moderately long, hard, and sustained turns, the engine feels like it is starved for fuel. it will never die, simply it loses almost all power until i straighten out.
what i've done:
-checked timing (fine)
-fuel pressure at 30 psi
-new fuel filter
obviously, i can't check the fuel pressure while turning (actually, maybe that's not so obvious. i could probably rig a hose into the cockpit....) -- it just feels like fuel starvation..
any ideas? thanks,
nathan
ps car is a 75 2.0 (Djet)
btw, i'm open to the possibility that this may not be a fuel delivery problem, but i recently went through the ignition system, installed a crane xr700, cleaned up grounds, new FI points, etc.
nebreitling
post Mar 19 2004, 05:27 PM
Member Emeritus
good question. the answer is:
i don't know.
i upgraded the ignition and changed the FI trigger points at the same time because the car started running horribly. now it runs like a champ in a straight line, coughs in the corners.
nebreitling   fuel starvation while turning   Mar 19 2004, 05:06 PM
vsg914   Is this a new problem since you upgraded the ignit...   Mar 19 2004, 05:16 PM
nebreitling   good question. the answer is: i don't know. ...   Mar 19 2004, 05:27 PM
Jeffs9146   Maybe something in the tank? Low oil pressure? Bad...   Mar 19 2004, 05:45 PM
nebreitling   okay, it's not a dip in fuel pressure that...   Mar 19 2004, 06:44 PM
Bruce Allert
- Lo-Fi Version Time is now: 1st July 2025 - 08:19 AM
