> Just had to have them!, 5 lug upgrade
mgphoto
post Sep 15 2010, 01:42 PM
"If there is a mistake it will find me"
I just wanted to share a project that I had been planning for the last 20 years, a 5 lug changeover.
I had been gathering the parts for a long time and I finally said I was gonna do it, I set the time aside (planned on it taking 7 days but small problems came up and a total of 11 days) and here is the result.
type47
post Sep 16 2010, 06:11 AM
Viermeister
What stub axels did you use?
mgphoto
post Sep 16 2010, 10:01 AM
QUOTE(type47 @ Sep 16 2010, 05:11 AM) *
Hey type47,
The very last items I found were a pair of 914/6 stub axles, I was going with a 4 lug converted hub set up, so when I found the stub axles I changed, since I had a pair of '72 911 hubs on the shelf that had 60mm studs which I swapped out for the standard 45mm,) I am a bit happier because the 4 lug hub does not line up with the screw holes in the brake disk. Fastening the disk to the hub this makes it much easier to adjust the venting clearance and the brake disk is centered on the hub so balance does not become an issue.
Mike
oldschool
post Sep 16 2010, 05:04 PM
QUOTE(mgphoto @ Sep 16 2010, 09:01 AM) *
Hey type47,
Mike
what do you do in the media world? (IMG:style_emoticons/default/shades.gif)
mgphoto
post Sep 16 2010, 05:13 PM
bump
- Lo-Fi Version Time is now: 15th April 2026 - 02:42 AM
