| mgphoto |
Sep 15 2010, 01:42 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,431 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I just wanted to share a project that I had been planning for the last 20 years, a 5 lug changeover.
I had been gathering the parts for a long time and I finally said I was gonna do it, I set the time aside (planned on it taking 7 days but small problems came up and a total of 11 days) and here is the result. ![]() |
| type47 |
Sep 16 2010, 06:11 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
What stub axels did you use?
| mgphoto |
Sep 16 2010, 10:01 AM
What stub axels did you use? Hey type47, The very last items I found were a pair of 914/6 stub axles, I was going with a 4 lug converted hub set up, so when I found the stub axles I changed, since I had a pair of '72 911 hubs on the shelf that had 60mm studs which I swapped out for the standard 45mm,) I am a bit happier because the 4 lug hub does not line up with the screw holes in the brake disk. Fastening the disk to the hub this makes it much easier to adjust the venting clearance and the brake disk is centered on the hub so balance does not become an issue. Mike |
| oldschool |
Sep 16 2010, 05:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,374 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
What stub axels did you use? Hey type47, The very last items I found were a pair of 914/6 stub axles, I was going with a 4 lug converted hub set up, so when I found the stub axles I changed, since I had a pair of '72 911 hubs on the shelf that had 60mm studs which I swapped out for the standard 45mm,) I am a bit happier because the 4 lug hub does not line up with the screw holes in the brake disk. Fastening the disk to the hub this makes it much easier to adjust the venting clearance and the brake disk is centered on the hub so balance does not become an issue. Mike what do you do in the media world? (IMG:style_emoticons/default/shades.gif) |
| mgphoto |
Sep 16 2010, 05:14 PM
bump
mgphoto Just had to have them! Sep 15 2010, 01:42 PM
pcar916 Lookin' good!!! :Qarl: :beer2: Sep 15 2010, 01:50 PM
mgphoto The project kicked off with a rebuild of my transm... Sep 15 2010, 01:52 PM
Sleepin Very nice!!!! Sep 15 2010, 02:32 PM
mgphoto bump Sep 16 2010, 05:13 PM
mgphoto
[quote name='mgphoto' post='1371640' date='Sep 16... Sep 16 2010, 05:16 PM
oldschool
[quote name='mgphoto' post='1371640' date='Sep 1... Sep 16 2010, 05:39 PM
qa1142 Very nice :shades2:
Only took me 6 years to dec... Sep 16 2010, 06:40 AM
Eric_Shea Looks awesome Mike.
Hows the first drive impressi... Sep 16 2010, 07:15 AM
mgphoto
Looks awesome Mike.
Hows the first drive impress... Sep 16 2010, 12:17 PM
Eric_Shea Gone but not forgotten is that "I'm pilot... Sep 16 2010, 03:56 PM
mgphoto A bit more than a month now and I needed to remove... Oct 24 2010, 01:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 12:58 AM |
