My car refuses to shift into 2 gear, I have no clue were to start |
weird_looking_cactus |
Mar 19 2004, 10:18 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
When I had the car running and was able to drive it the car, it would not shift into second gear. It had a pushing filling on it when I would try to go into that gear. Also even though I have the clutch all the way in and changing gears like from reverse to first it would make a big grinding noise but only once in a while. So Im thinking I need to tighten my cable to stop the grinding noise. But I have no clue about how to fix second gear. My car is a 1975 2.0 with side shifter. Thanks for those who help.
Bleyseng |
Mar 20 2004, 06:15 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Have you looked inside the rear cover at the shifter bushings? You can undo the shifter cup and then shift the car into all the gears-1st/rev-2nd/3rd-4th/5th try it to see if this works.
Lo-Fi Version | Time is now: 8th June 2024 - 01:13 PM |
