the sawtooth build thread |
sawtooth |
Aug 23 2008, 05:56 PM
Member Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region |
Wanted to start a build thread for my na suby conversion. The car is my newly acquired '73 2.0L fi. It is very clean, appearance group, 2nd owner, 88K. I currently use it as my daily driver.
I want to do a suby conversion because I believe the overall package will have the performance, drivability, and dependability I'm looking for. EDIT: I've changed motor selection slightly and am also taking a bigger plunge by going with a suby trans, see Post #49. |
Zaney |
Sep 23 2010, 02:07 PM
Deuchland en der Haus Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest |
sawtooth |
Sep 23 2010, 02:45 PM
Sadly the battle has been stalled for a while now. I get distracted easily, man I need a local support group or something to keep me giong (IMG:style_emoticons/default/headbang.gif) Very few 914s around here. But reading great threads like yours almost daily has me fired up to get going again. Just got a couple small projects to get out of the way and then I hope to be back at it. Engine and trans are in, radiator setup is mostly finished (changed to up front), in the process of running new ss fuel lines and reconditioning fuel tank. Then installing wiring harness and hopefully firing it up soon. Question for you.. what axle solution will you be using with your suby trans? I did pick up a suby 5spd MT and am really excited to that conversion at some point. But I'm going to treat it as a completely separate conversion later since I already have a kennedy adapter setup. Just collecting parts now. Man thanks for the :bump Keep up the great work on yours, I'm counting on it for inspiration. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:25 PM |
