the sawtooth build thread |
sawtooth |
Aug 23 2008, 05:56 PM
Member Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region |
Wanted to start a build thread for my na suby conversion. The car is my newly acquired '73 2.0L fi. It is very clean, appearance group, 2nd owner, 88K. I currently use it as my daily driver.
I want to do a suby conversion because I believe the overall package will have the performance, drivability, and dependability I'm looking for. EDIT: I've changed motor selection slightly and am also taking a bigger plunge by going with a suby trans, see Post #49. |
charliew |
Sep 24 2010, 01:11 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Sequential tranny as in the new suby sequential tranny? I read up on it and it's doesn't support much hp or torque. I really want to do a sequential tranny but haven't come up with a cost effective solution yet. I considered try to design a shifter that would work with the suby tranny but it is not to the must have stage yet. One missed downshift with a suby at high rpm will make the sequential tranny much more important though. My son hotrods a 425 hp sti and missed 5th in the 1/4 mile and putting it in third at 7500 in 4th is tough on ringlands, it probably went over 9k before he got the clutch back in. Luckily he has forged pistons in it.
Hontec |
Sep 24 2010, 01:26 PM
I see things..... Group: Members Posts: 261 Joined: 23-September 10 From: Netherlands Member No.: 12,210 Region Association: Europe |
Sequential tranny as in the new suby sequential tranny? I read up on it and it's doesn't support much hp or torque. I really want to do a sequential tranny but haven't come up with a cost effective solution yet. I considered try to design a shifter that would work with the suby tranny but it is not to the must have stage yet. One missed downshift with a suby at high rpm will make the sequential tranny much more important though. My son hotrods a 425 hp sti and missed 5th in the 1/4 mile and putting it in third at 7500 in 4th is tough on ringlands, it probably went over 9k before he got the clutch back in. Luckily he has forged pistons in it. The Elite transmissions gearbox holds 425 LBS/ft which is 575NM, that will do I think.. Second plus is that it is exactly the same on the outside as the oem subaru box, it fits directly to the subaru engine, no adapterplates, uses stock subaru flywheel and clutch parts etc etc..... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.eliteracingtransmissions.com-12210-1285356413.1.png) The Mendeola holds even more power, works with an adapter plate which is developed by OUTfront motorsports for the baya's . the plate is very short and brings the axle closer to the engine, benefit is that if you want to upgrade in the future to let's say a V8 (LS6), you just change the adapterplate..... |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:05 PM |
