Loose front trunk hinges. Is this Normal? |
yrret7 |
Sep 26 2010, 11:11 PM
Newbie Group: Members Posts: 18 Joined: 21-September 10 From: Kingston Ont, Canada Member No.: 12,202 Region Association: Canada |
I removed my front trunk lid to line up the hood better and found that the hinges are very loose. Once the tension of the spring was removed it was even worse. Is this normal? I thought perhaps the bolt was loose but this was not the case. I'm not sure if the hole has increased in size or if the shouldered bolt is worn smaller. Would a washer help ? Anyone had this issue before?
Thanks!! |
TheCabinetmaker |
Sep 27 2010, 06:12 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Its been a while, but, I think there is a plastic bushing that the bolt goes thru.
Bartlett 914 |
Sep 27 2010, 07:44 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Its been a while, but, I think there is a plastic bushing that the bolt goes thru. Steel bolt in a steel hole. Often freezes up from rust. This is a place where there should be a place to lubricate. The bolt head doesn't allow easy lubricating. The hinges are a little loose on the cars I have seen. Better loose than frozen. In the rear the bolts are the same. The part mounted to the car is not as rigid. It is also a little more exposed to the elements and rusts a little faster. These will rust up and rip the bracket off the car. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:11 AM |
