Loose front trunk hinges. Is this Normal? |
yrret7 |
Sep 26 2010, 11:11 PM
Newbie Group: Members Posts: 18 Joined: 21-September 10 From: Kingston Ont, Canada Member No.: 12,202 Region Association: Canada |
I removed my front trunk lid to line up the hood better and found that the hinges are very loose. Once the tension of the spring was removed it was even worse. Is this normal? I thought perhaps the bolt was loose but this was not the case. I'm not sure if the hole has increased in size or if the shouldered bolt is worn smaller. Would a washer help ? Anyone had this issue before?
Thanks!! |
Bartlett 914 |
Sep 27 2010, 10:20 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
The bolt is special. It is a shoulder bolt. Adding washers will prevent the hinge from operating. The hinge is steel on steel. The diameter is 12mm. Is this the bolt you have? The fit is pretty close. Measure the shoulder diameter on your bolt. It may be worn out. It could also be the hinge hole. There are plenty available. Ask on the parts forum.
Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 04:48 AM |
