RonnieJ |
RonnieJ ![]() ![]() Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest ![]() |
The sealant on my relay board in the engine compartment is getting old and crumbling on the underside...what is used to reseal it?
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
What the Vagabond tech sheet is refering to is each component's sensitivity to moisture before they're mixed together. This is common with two-component polyurethane casting materials. Optimally you'd evacuate the mixture before casting to remove entrapped air and moisture.
Andys |
Lo-Fi Version | Time is now: 2nd July 2025 - 11:36 PM |
