Tranny paper spacers, need thicknesses |
Chris914n6 |
Mar 21 2004, 03:47 PM
Jackstands are my life. Group: Members Posts: 3,341 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I need to know the thicknesses of the paper seals/spacers so I can reset my r&p depth.
Had to combine some pieces to get a good tranny... and add the H gear 5th (IMG:style_emoticons/default/smile.gif) Thanks, Chris |
TimT |
Mar 21 2004, 05:35 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Do a "prussian blue" test, or if you dont have some machinists dye around, use some white grease.. put a nice but not to thick coat on the ring gear.. assemble the tranny with whatever gasket you have..put the tranny in gear, rotate the input shaft so everything is turning in the forward direction...
the pull the diff out, check the "smear" on the ring gear teeth.... if the white grease has a wear pattern halfway up, and halfway down, just go with it...if the wear or wipe is to high on the ring gear use a thicker shim.. Most of our cars dont make enough power to be really to concerned about perfect r/p depth...if we dont get it right we just hear a bit more whine from the tranny.. unlike my friends 3.8 twin turbo which shears teeth off a G50/50 ring gear (IMG:style_emoticons/default/cool.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 12:49 AM |
