Front end changeover in progress..., 8/8- Alignment woes |
jk76.914 |
Sep 9 2010, 07:45 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I'm finally getting rid of the 4-to-5 lug adapters and doing a real Porsche 5 lug front suspension. Contrary to normal practice, which is normal for me, I guess, I'm installing real 914/6 struts with new Bilstein inserts. I bought the parts about 5 years ago on eBay, and the kit was all-inclusive, with freshly painted struts and new ball joints, bearings, rotors, pads, and brake hardware, and rebuilt M calipers. My excuse is I didn't know any better at the time, or I'd have looked for a later 911 set with the later bearing type, but alas, I own it now and everything is in real nice shape.
I think I'm good to go on parts and tools, but I'm trying to find out the torque requirement for the lock bolt for the ball joint. It's an M10 x 30mm x 1.5mm pitch, going into steel threads in the strut; presumably the lower part of the strut, below the tube, is forged. Looks like an M10 grade 12.9 bolt is good for 50 ft-lbs, but I don't want to chance stripping out the threads. Nor do I want the BJ to pop because it's too loose. Does anyone know the torque spec? Thanks! Picture below- PS- any tips for installing this type of strut? Thanks! |
Eric_Shea |
Sep 29 2010, 07:00 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Factory Manual = 47ftlbs.
QUOTE My excuse is I didn't know any better at the time, or I'd have looked for a later 911 set with the later bearing type, but alas, I own it now and everything is in real nice shape. Not following... you mean later ball joint? Those struts are fine. As long as your holes in the bottom are round you're good. 99.9% of them are fine. One article in Pano and the world thinks early pinch struts are all bad. (IMG:style_emoticons/default/biggrin.gif) Those are my favorite struts for a 914. Good choice. (IMG:style_emoticons/default/smilie_pokal.gif) |
ArtechnikA |
Sep 30 2010, 04:43 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
99.9% of them are fine. One article in Pano and the world thinks early pinch struts are all bad. Maybe it was just the luck of the draw but I had two bad ones on one car at a time I really didn't need the expense of replacing two struts. (This was a long time ago, they are long gone now.) There was a pair of those on my 911 and as soon as I can get the $%$## stuck ball joints, upper bearings, and tie rod ends out, I'll be glad to be rid of them. Especially now that they have been deemed 'highly prized' ;-) |
Lo-Fi Version | Time is now: 11th June 2024 - 03:33 PM |
