Loose front trunk hinges. Is this Normal? |
yrret7 |
Sep 26 2010, 11:11 PM
Newbie Group: Members Posts: 18 Joined: 21-September 10 From: Kingston Ont, Canada Member No.: 12,202 Region Association: Canada |
I removed my front trunk lid to line up the hood better and found that the hinges are very loose. Once the tension of the spring was removed it was even worse. Is this normal? I thought perhaps the bolt was loose but this was not the case. I'm not sure if the hole has increased in size or if the shouldered bolt is worn smaller. Would a washer help ? Anyone had this issue before?
Thanks!! |
swl |
Oct 2 2010, 07:53 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Show us the car yrret! (IMG:style_emoticons/default/wink.gif)
here's a link to the pic posting instructions. Make sure the resolution isn't too high. If you have problems I'm sure you could find a geeky neighbor to help (IMG:style_emoticons/default/smile.gif) http://www.914world.com/bbs2/index.php?showtopic=13637 |
Lo-Fi Version | Time is now: 8th June 2024 - 04:51 AM |
