> fuel pump, '74 2.0 fuel injected
huey
post Oct 21 2010, 05:28 PM
What would be causing my reconditioned fuel pump to burn out? I have tried replacing gas line filter, I made sure the return fuel line was good, I removed all the gas from the tank to the fuel pump. I have burned out 2 pumps so far.
What can I be checking to get my headlights to raise and lower?
SLITS
post Oct 21 2010, 05:42 PM
"This Utah shit is HARSH!"
1.) Poor quality rebuild. Bosch says they can't be rebuilt. If you have the capability, check the amp draw on your pump.
2.) Insufficient fuel flow ... clogged restricted suction or return ... pump overheats as it is cooled by fuel flow
3.) Pump to close to HEs and overheating.
Just get a new '75-'76 single in and single out and eliminate the "t" at the pump.
Headlights:
1.) headlight switch internally bad
2.) bad relays (front trunk)
3.) bad headlight motors
4.) bad wiring
that's about it for me.
huey   fuel pump   Oct 21 2010, 05:28 PM
SLITS   1.) Poor quality rebuild. Bosch says they can...   Oct 21 2010, 05:42 PM
914Sixer   Each headlight has a fuse under the dash and a rel...   Oct 21 2010, 06:59 PM
- Lo-Fi Version Time is now: 25th June 2026 - 11:13 AM
