> fuel pump, '74 2.0 fuel injected
huey
post Oct 21 2010, 05:28 PM
What would be causing my reconditioned fuel pump to burn out? I have tried replacing gas line filter, I made sure the return fuel line was good, I removed all the gas from the tank to the fuel pump. I have burned out 2 pumps so far.
What can I be checking to get my headlights to raise and lower?
914Sixer
post Oct 21 2010, 06:59 PM
Each headlight has a fuse under the dash and a relay under each cover in the front. Relay controls motor, fuse controls the headlight. Check headlight motor ground on back of headlight bucket.
huey   fuel pump   Oct 21 2010, 05:28 PM
SLITS   1.) Poor quality rebuild. Bosch says they can...   Oct 21 2010, 05:42 PM
914Sixer   Each headlight has a fuse under the dash and a rel...   Oct 21 2010, 06:59 PM
- Lo-Fi Version Time is now: 25th June 2026 - 12:34 PM
