> Winter storage, Trickle charger for Optima battery?
championgt1
post Oct 22 2010, 09:10 AM
Don't embarrass me Filmore!
So, the Optima battery can't be charged like a normal battery. What are you guys using for a trickle charger/maintaner when storing your car for the winter? The good, the bad. What to get?
championgt1
post Oct 22 2010, 10:30 AM
From Optimas website.
OPTIMA RedTop Charging Information
The following charging methods are recommended to insure a long battery life - always use a voltage-regulated charger, with voltage limits set as described below.
RedTop Type: 34 & 34R - 34/78 - 78 - 25 & 35 - 75/25
These batteries are designed for engine starting applications. They are NOT recommended or warranted for use in deep cycle applications.
Recommended charging information:
Alternator:
■13.3 to 15.0 volts, no amperage limit.
Battery Charger:
■13.8 to 15.0 volts, 10 amps maximum, 6-12 hours approximate.
Rapid Recharge:
■Maximum voltage 15.6 volts (regulated), no current limit as long as battery temperature remains below 125°F (51.7°C). Charge until current drops below 1 amp.
Float Charge:
■13.2 to 13.8 volts, 1 amp maximum current, time indefinite (at lower voltage).
All limits must be strictly adhered to.
Safety Information:
■Always wear safety glasses when working with batteries.
■Always use a voltage regulated battery charger with limits set to the above ratings. Overcharging can cause the safety valves to open and battery gasses to escape, resulting in premature failure. These gasses are flammable! You cannot replace water in sealed batteries that have been overcharged. Any battery that becomes very hot or makes a hissing sound while recharging should be disconnected immediately.
■Failure to fully charge a battery can result in poor performance and a reduction in capacity.
championgt1   Winter storage   Oct 22 2010, 09:10 AM
StratPlayer   I pull the battery out of the car and bring it ins...   Oct 22 2010, 09:14 AM
PeeGreen 914   I pull the battery out of the car and bring it in...   Oct 22 2010, 09:59 AM
Cupomeat   Please enlighten me! What happens when you us...   Oct 22 2010, 10:04 AM
realred914   well I have charged Optimas "normally' s...   Oct 22 2010, 10:06 AM
race914   I've used a 'regular' battery charger ...   Oct 22 2010, 10:10 AM
iamchappy   I use a Battery Minder on mine...   Oct 22 2010, 10:21 AM
jt914-6   I've got the NAPA version of the Optima....hav...   Oct 22 2010, 10:22 AM
championgt1   From Optimas website. OPTIMA RedTop Charging In...   Oct 22 2010, 10:30 AM
black73   Hot Rod magazine had an article about this... h...   Oct 22 2010, 05:49 PM
underthetire   I just get a Harbor freight float charger, they ar...   Oct 23 2010, 08:05 AM
Drums66   I just get a Harbor freight float charger, they a...   Oct 23 2010, 02:13 PM
ConeDodger   I bought a CTek battery tender and connector ends ...   Oct 23 2010, 08:12 AM
Tom   Also from the Optima site under storage; ...   Oct 23 2010, 08:23 AM
computers4kids   I drive my teener year round so need to pack it aw...   Oct 23 2010, 08:52 AM
Bartlett 914   I would only like to add that I have an "Orbi...   Oct 23 2010, 09:49 AM
Mikey914   I'd probably leave it in the car disconnected,...   Oct 23 2010, 09:54 AM
smg914   I've been using Schumacher battery maintainers...   Oct 23 2010, 11:31 AM
- Lo-Fi Version Time is now: 4th July 2025 - 08:15 PM
