| Scott S |
Oct 22 2010, 02:57 PM
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All –
I cut the hole in my firewall for my conversion. I am going to attach the new steel access plate using screws on the interior, and then welding in some captured nuts on the engine compartment side of the firewall. Being that each nut will just get a quick zap of a couple of spot welds, do I need to worry about what finish is on the nuts (raw vs zinc, etc)? Thanks! (IMG:style_emoticons/default/beerchug.gif) |
Elliot Cannon You could always rivet some nut plates instead of ... Oct 22 2010, 03:12 PM
realred914 for your application probably no worry if plated o... Oct 22 2010, 03:54 PM
bugsy0 nutcerts or similar are the way to go - no burned ... Oct 22 2010, 04:01 PM
Andyrew I'd take a quick grind to the edge's your ... Oct 22 2010, 05:47 PM
McMark :agree: remove the zinc plating before welding. I... Oct 22 2010, 08:54 PM
majkos Oh! Good idea! :agree:
I'll do that o... Oct 23 2010, 07:57 AM
9146986 The nut inserts work great. Weld nuts are better ... Oct 23 2010, 03:02 PM
plymouth37 If you have an air powered rivet gun (or the muscl... Oct 23 2010, 04:14 PM
URY914 I always put a bolt thru the nut before I weld the... Oct 24 2010, 08:39 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 08:07 PM |
