| IronHillRestorations |
Oct 21 2010, 12:08 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,926 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Anyone here done a later CIS conversion with the O2 control box. I'm working with BJ on his 3.0 conversion and would like to hear from someone that's gone this route. THANKS!!
| Jeffs9146 |
Oct 24 2010, 12:28 AM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
but I have not heard you talk about the clutch or flywheel yet so......yes it can get pricy! Have you done the oil cooler mod yet? I won't cut mine because it is an original 6 but if I had a 4, and I was planning an engine upgrade, then I would just cut it! Thats my $.02! PS: If you plan on carbs you will loose some HP and some other details if you don't change the cams from FI to Carb config.! |
| Bee Jay |
Oct 24 2010, 08:34 AM
Member ![]() ![]() Group: Members Posts: 204 Joined: 22-April 05 From: Lompoc, Ca. Member No.: 3,964 |
(IMG:style_emoticons/default/agree.gif) but I have not heard you talk about the clutch or flywheel yet so......yes it can get pricy! Have you done the oil cooler mod yet? I won't cut mine because it is an original 6 but if I had a 4, and I was planning an engine upgrade, then I would just cut it! Thats my $.02! PS: If you plan on carbs you will loose some HP and some other details if you don't change the cams from FI to Carb config.! The oil cooler has been mofified. I either need a whole new flywheel or just the ring gear to mount this 3.0 to my 901, depending on who I've talked to last. All I got with the engine is the 3.0 flywheel, no ring gear. What is it I should cut? Please keep chiping in your $.02, I really appreciate any advice. Nice web page, you party animal, you. Where is Discovery Bay? Thanks Bee Jay |
9146986 '83 3.0 with CIS in a 914 Oct 21 2010, 12:08 PM
sixnotfour if you get a harness it should be easy.
http://cgi... Oct 21 2010, 05:14 PM
Cap'n Krusty
http://cg... Oct 21 2010, 05:47 PM
Bee Jay
[quote name='sixnotfour' post='1385486' date='Oct... Oct 22 2010, 11:00 AM
SLITS I will do it someday, but I am going to eliminate ... Oct 21 2010, 05:47 PM
JmuRiz
I will do it someday, but I am going to eliminate... Oct 21 2010, 06:59 PM
sixnotfour
I wouldnt never run that stuff , Im with you Ron,... Oct 21 2010, 07:15 PM
jcd914
78-79 3.0 didnt have lamb control.
Yea but the... Oct 21 2010, 11:02 PM
Jeffs9146 This is my goal! Oct 22 2010, 08:57 AM
Ferg That's my old 2.7, I took that picture on the ... Oct 22 2010, 09:21 AM
sixnotfour
agreed just effin with slits, 3.2 motronic, now y... Oct 22 2010, 10:03 AM
Jeffs9146
What was that airbox from, and what parts did yo... Oct 22 2010, 10:21 AM
Ferg
What was that airbox from, and what parts did y... Oct 22 2010, 11:13 AM
Cap'n Krusty I don't think he needs it to build you a main ... Oct 22 2010, 11:10 AM
Bee Jay
I don't think he needs it to build you a main... Oct 22 2010, 11:44 AM
Jeffs9146 :agree: The Cap'n is right the harness is a st... Oct 22 2010, 12:41 PM
Bee Jay
:agree: The Cap'n is right the harness is a s... Oct 22 2010, 02:18 PM
montoya 73 2.0 Could you use a Aluminum Air box? I think I have a... Oct 22 2010, 01:56 PM
SLITS I used the 914/4 engine harness and relay board on... Oct 22 2010, 02:30 PM
Jeffs9146 Yes there is a fuse panel that the harness plugs i... Oct 22 2010, 02:32 PM
patssle What is that little silver box with the green wire... Oct 22 2010, 04:35 PM
Cap'n Krusty
What is that little silver box with the green wir... Oct 22 2010, 04:52 PM
Jeffs9146
I'll take it!! How much?? Oct 22 2010, 07:23 PM
Jeffs9146 I left my camera at my girlfriends house in SF so ... Oct 22 2010, 07:27 PM
Maltese Falcon Perry, mount the Bosch control box in the rear tru... Oct 23 2010, 12:24 AM
Bee Jay I pulled my CIS stuff out last night to start clea... Oct 23 2010, 01:19 PM
9146986 I'll call you tonight or tomorrow BeeJay. Oct 23 2010, 02:42 PM
pete-stevers or....you could just lower the engine mounts by an... Oct 24 2010, 12:00 AM
9146986
:agree:
PS: If you plan on carbs you will loose... Oct 24 2010, 09:03 AM
sixnotfour Here is something else to sleep on.
http://www.bit... Oct 24 2010, 08:57 AM
J P Stein Gee, Perry, it's not like you're new to th... Oct 24 2010, 09:23 AM
Jeffs9146
OK miss stated your torque curve will change and... Oct 24 2010, 09:55 AM
patssle
I have a 3.0L CIS that will be converted to carb... Oct 24 2010, 10:38 AM
Jeffs9146 I purchased the kit from Patrick Motor Sports that... Oct 24 2010, 10:49 AM
JmuRiz What's the consensus, on a budget, on using a ... Oct 25 2010, 01:39 PM
patssle
What's the consensus, on a budget, on using a... Oct 25 2010, 04:09 PM
RickS Am going with a 3.0 with Webbers using MSD. No mu... Oct 25 2010, 03:49 PM
SLITS Ok, I have done two CIS conversions and have not c... Oct 25 2010, 04:38 PM
patssle
Yes, if you mount the engine lower you don't... Oct 25 2010, 05:03 PM
SLITS
Yes, if you mount the engine lower you don... Oct 25 2010, 05:25 PM
pete-stevers if you drop it an inch you will need to rework the... Oct 25 2010, 08:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:25 AM |
