beemie96 |
Member ![]() ![]() Group: Members Posts: 98 Joined: 15-July 04 From: Nashville, TN Member No.: 2,350 ![]() |
I've been working on getting this car road-worthy for a while now - and I was so close!
I had it running but it would overheat, so I dropped the engine and cleaned it off and put it all back together and got it running, but the clutch got stuck... so I rolled it in 5 gear with the clutch engaged and freed it up. I idled the car for 20 minutes with some ATF to clean out some gunk. All good... Then - I put the gas tank back in the car and must have crimped the fuel line. I think I burned the pump out because it won't run at all! So i went and got an aftermarket late model pump (1972 914) - and it worked fine ... I idled the car for 30 minutes again, then went to drive it and ... no dice! The engine would die when I released the clutch in gear. Now, I can't even get it to idle. the pressure will start in the mid-20s and the car will start , but only run for about 10 seconds. Then it won't start for a while again... did I burn this pump out somehow too? Maybe ran it without gas in the car? If it couldn't push the car, I probably had a crappy pump anyway, right? Since that's the only thing that has changed since it ran... I'm just hoping maybe I can refurbish one of the two pumps instead of buying another one. Unless someone can sell me one cheap... Thanks all! |
poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,139 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
Must be a TN thing... I have a similar problem. Car starts and idles great. Try to rev and it only gets to 2500-3000 rpm. Have to be super easy on the clutch to get the car moving. After it dies, hard to start if at all.
I have no way to check the pressure but today am going to double check the lines from the tank to the pump to be sure no crimps, blockage, etc. If I end up replacing the pump, I am going with an aftermarket two port. |
Lo-Fi Version | Time is now: 1st August 2025 - 04:39 AM |
