> '83 3.0 with CIS in a 914, Anyone here done it? With the O2 control box?
IronHillRestorations
post Oct 21 2010, 12:08 PM
I. I. R. C.
Anyone here done a later CIS conversion with the O2 control box. I'm working with BJ on his 3.0 conversion and would like to hear from someone that's gone this route. THANKS!!
patssle
post Oct 24 2010, 10:38 AM
I either need a whole new flywheel or just the ring gear to mount this 3.0 to my 901, depending on who I've talked to last. All I got with the engine is the 3.0 flywheel, no ring gear.
What is it I should cut?
I have a 3.0L CIS that will be converted to carbs and put into my 914. That is the plan as of now anyways. I get confused by the flywheel info, everybody says different stuff. I've read that you can keep the flywheel, but need to change the pressure plate. Or change the flywheel and keep the same pressure plate. Then the ringgear comes into play, what's needed on that?
@Beejay: Too bad we don't have better timing, I plan on selling all my CIS stuff once I tear it off the engine. And it works too. No idea when that will happen.
9146986   '83 3.0 with CIS in a 914   Oct 21 2010, 12:08 PM
sixnotfour   if you get a harness it should be easy. http://cgi...   Oct 21 2010, 05:14 PM
Cap'n Krusty   if you get a harness it should be easy. http://cg...   Oct 21 2010, 05:47 PM
Bee Jay   [quote name='sixnotfour' post='1385486' date='Oct...   Oct 22 2010, 11:00 AM
SLITS   I will do it someday, but I am going to eliminate ...   Oct 21 2010, 05:47 PM
JmuRiz   I will do it someday, but I am going to eliminate...   Oct 21 2010, 06:59 PM
sixnotfour   I wouldnt never run that stuff , Im with you Ron,...   Oct 21 2010, 07:15 PM
jcd914   78-79 3.0 didnt have lamb control. Yea but the...   Oct 21 2010, 11:02 PM
Jeffs9146   This is my goal!   Oct 22 2010, 08:57 AM
Ferg   That's my old 2.7, I took that picture on the ...   Oct 22 2010, 09:21 AM
sixnotfour   agreed just effin with slits, 3.2 motronic, now y...   Oct 22 2010, 10:03 AM
Jeffs9146   What was that airbox from, and what parts did yo...   Oct 22 2010, 10:21 AM
Ferg   What was that airbox from, and what parts did y...   Oct 22 2010, 11:13 AM
Cap'n Krusty   I don't think he needs it to build you a main ...   Oct 22 2010, 11:10 AM
Bee Jay   I don't think he needs it to build you a main...   Oct 22 2010, 11:44 AM
Jeffs9146   :agree: The Cap'n is right the harness is a st...   Oct 22 2010, 12:41 PM
Bee Jay   :agree: The Cap'n is right the harness is a s...   Oct 22 2010, 02:18 PM
montoya 73 2.0   Could you use a Aluminum Air box? I think I have a...   Oct 22 2010, 01:56 PM
SLITS   I used the 914/4 engine harness and relay board on...   Oct 22 2010, 02:30 PM
Jeffs9146   Yes there is a fuse panel that the harness plugs i...   Oct 22 2010, 02:32 PM
patssle   What is that little silver box with the green wire...   Oct 22 2010, 04:35 PM
Cap'n Krusty   What is that little silver box with the green wir...   Oct 22 2010, 04:52 PM
Jeffs9146   I'll take it!! How much??   Oct 22 2010, 07:23 PM
Jeffs9146   I left my camera at my girlfriends house in SF so ...   Oct 22 2010, 07:27 PM
Maltese Falcon   Perry, mount the Bosch control box in the rear tru...   Oct 23 2010, 12:24 AM
Bee Jay   I pulled my CIS stuff out last night to start clea...   Oct 23 2010, 01:19 PM
9146986   I'll call you tonight or tomorrow BeeJay.   Oct 23 2010, 02:42 PM
pete-stevers   or....you could just lower the engine mounts by an...   Oct 24 2010, 12:00 AM
Jeffs9146   :agree: but I have not heard you talk about the ...   Oct 24 2010, 12:28 AM
Bee Jay   :agree: but I have not heard you talk about the...   Oct 24 2010, 08:34 AM
9146986   :agree: PS: If you plan on carbs you will loose...   Oct 24 2010, 09:03 AM
sixnotfour   Here is something else to sleep on. http://www.bit...   Oct 24 2010, 08:57 AM
J P Stein   Gee, Perry, it's not like you're new to th...   Oct 24 2010, 09:23 AM
Jeffs9146   OK miss stated your torque curve will change and...   Oct 24 2010, 09:55 AM
patssle   I have a 3.0L CIS that will be converted to carb...   Oct 24 2010, 10:38 AM
Jeffs9146   I purchased the kit from Patrick Motor Sports that...   Oct 24 2010, 10:49 AM
JmuRiz   What's the consensus, on a budget, on using a ...   Oct 25 2010, 01:39 PM
patssle   What's the consensus, on a budget, on using a...   Oct 25 2010, 04:09 PM
RickS   Am going with a 3.0 with Webbers using MSD. No mu...   Oct 25 2010, 03:49 PM
SLITS   Ok, I have done two CIS conversions and have not c...   Oct 25 2010, 04:38 PM
patssle   Yes, if you mount the engine lower you don't...   Oct 25 2010, 05:03 PM
SLITS   Yes, if you mount the engine lower you don...   Oct 25 2010, 05:25 PM
pete-stevers   if you drop it an inch you will need to rework the...   Oct 25 2010, 08:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:40 PM
