| jeffdon |
Oct 23 2010, 01:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Got a wierd one. My turn signals all work fine with the headlights off. With them on, the rights work, but the lefts (front and rear) do not. What could this be? For what its worth, but I dont think its got any effect, I deleted the hockey puck side markers.
| Mike Bellis |
Oct 23 2010, 02:47 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
The front left turn signal housing is wired wrong. you system is pulling its ground through the head light circuit. Possibly the front left signal ground is broken
| Spoke |
Oct 24 2010, 10:47 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,438 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
The front left turn signal housing is wired wrong. you system is pulling its ground through the head light circuit. Possibly the front left signal ground is broken (IMG:style_emoticons/default/agree.gif) Remove the turn signal lense and make sure just the bright filament is on when the turn signal is on. This will confirm the issue. Also with the parking light on, just the dim filament should be lit. |
jeffdon Turn signal question Oct 23 2010, 01:31 PM
Drums66 ...Check the bulb socket's 1st :idea:
:waveb... Oct 23 2010, 02:43 PM
76-914
The front left turn signal housing is wired wrong... Oct 23 2010, 03:02 PM
kenshapiro2002 Mine was the relay Oct 25 2010, 05:20 AM![]() ![]() |
Lo-Fi Version | Time is now: 26th November 2026 - 05:05 AM |
