beemie96 |
Member ![]() ![]() Group: Members Posts: 98 Joined: 15-July 04 From: Nashville, TN Member No.: 2,350 ![]() |
I've been working on getting this car road-worthy for a while now - and I was so close!
I had it running but it would overheat, so I dropped the engine and cleaned it off and put it all back together and got it running, but the clutch got stuck... so I rolled it in 5 gear with the clutch engaged and freed it up. I idled the car for 20 minutes with some ATF to clean out some gunk. All good... Then - I put the gas tank back in the car and must have crimped the fuel line. I think I burned the pump out because it won't run at all! So i went and got an aftermarket late model pump (1972 914) - and it worked fine ... I idled the car for 30 minutes again, then went to drive it and ... no dice! The engine would die when I released the clutch in gear. Now, I can't even get it to idle. the pressure will start in the mid-20s and the car will start , but only run for about 10 seconds. Then it won't start for a while again... did I burn this pump out somehow too? Maybe ran it without gas in the car? If it couldn't push the car, I probably had a crappy pump anyway, right? Since that's the only thing that has changed since it ran... I'm just hoping maybe I can refurbish one of the two pumps instead of buying another one. Unless someone can sell me one cheap... Thanks all! |
beemie96 |
Yeah, it's a new filter sock. I need to double check that I'm hooked to the right lines... new filter too, but that doesn't mean it isn't clogged.
I'll check to make sure there are no crimps... good thought... thanks. |
Lo-Fi Version | Time is now: 1st August 2025 - 04:50 AM |
