> Fuel Pressure only holds for 10 seconds, WTF? This car worked a couple weeks ago!
beemie96
post Oct 24 2010, 09:50 AM
I've been working on getting this car road-worthy for a while now - and I was so close!
I had it running but it would overheat, so I dropped the engine and cleaned it off and put it all back together and got it running, but the clutch got stuck... so I rolled it in 5 gear with the clutch engaged and freed it up.
I idled the car for 20 minutes with some ATF to clean out some gunk. All good...
Then - I put the gas tank back in the car and must have crimped the fuel line. I think I burned the pump out because it won't run at all!
So i went and got an aftermarket late model pump (1972 914) - and it worked fine ... I idled the car for 30 minutes again, then went to drive it and ... no dice! The engine would die when I released the clutch in gear.
Now, I can't even get it to idle. the pressure will start in the mid-20s and the car will start , but only run for about 10 seconds. Then it won't start for a while again...
did I burn this pump out somehow too? Maybe ran it without gas in the car?
If it couldn't push the car, I probably had a crappy pump anyway, right?
Since that's the only thing that has changed since it ran...
I'm just hoping maybe I can refurbish one of the two pumps instead of buying another one. Unless someone can sell me one cheap...
Thanks all!
hot_shoe914
post Oct 25 2010, 07:36 AM
on ramp passer
If you are still using the old 3 port fuel pump make sure you have the lines hooked up correctly. I changed mine once and mixed up the lines, it ran, but barely. Once I got the lines back in the correct spot it worked like a dream.
Shoe
beemie96
post Oct 25 2010, 07:53 AM
QUOTE(hot_shoe914 @ Oct 25 2010, 05:36 AM) *
Shoe
Unfortunately, the 3 port pump is burned out or something - if I ran it with the lines crimped, would it burn out so that it won't run at all? I definitely had the lines crimped at one point when I put the tank back in. Now I'm using a two port late model pump.
If I burned the 3 port out - could I take it apart and fix it at all?
- Lo-Fi Version Time is now: 1st August 2025 - 04:50 AM
