| Cairo94507 |
Oct 22 2010, 05:52 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,808 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
OK, so my car has a 3.0 with Webers. It has what to me appears to be a rather unusual oil cooling system:
![]() Has anyone ever seen something like this? I have a thermostat installed beck near the engine and then this copper pipe running to the front along the passenger side long and looping back to the engine. I guess it worked. Thanks. |
| Cairo94507 |
Oct 23 2010, 07:11 PM
It is copper all the way back to the engine. I plan to drive it to see how it works.
| stownsen914 |
Oct 25 2010, 11:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,039 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Is there any rubber hose between the engine and the copper pipe? If not, it is just a matter of time before they break, due to the engine movement relative to the chassis. If there are rubber lines in there somewhere to absorb the movement, then it will probably be OK at least for a while.
Scott |
Cairo94507 Different Oil Cooling System Oct 22 2010, 05:52 PM
Dr Evil Looks like a facsimile of the trombone cooler used... Oct 22 2010, 08:02 PM
Krieger Looks like Joe the Plumber owned that car! Do... Oct 22 2010, 08:13 PM
Cairo94507 According to the PO, it did not overheat, it does ... Oct 22 2010, 08:55 PM
McMark Keep an eye on the rubber/copper transitions and m... Oct 22 2010, 09:05 PM
Cairo94507 Thanks; that is exactly what I plan on doing. Bra... Oct 23 2010, 06:21 AM
carr914 If you used a F/G Front Bumper, you could do some ... Oct 23 2010, 06:44 AM
Mark Henry Is it copper or brass? the 90's look heavier t... Oct 23 2010, 06:57 PM
pete-stevers looks like it might be an easy change to a coil if... Oct 24 2010, 10:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th November 2026 - 10:18 AM |
