| 914itis |
Oct 26 2010, 08:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I changed my oil today using 20/50 brad penn, and I changed all the gaskets for the exhaust. the exaust sounds beautiful.
My friend was helping me and I decided to take him home. After driving 5 city blocks, I heard a weird noise like the fan is touching something (squeeking). pulled over turned off the car. I try to start the car, the noise is there as the starter is spining. Pushed the car back home, double check everything, even try to loosen the exhaust, the same thing. The noise looks like its coming from the starter or flyweel. I removed the coil cable so the car wont start, try to start it and there was no noise. I put the cable back, the car started and the noise dissapeared. but each time i start the car i hear the noise as the starter is spinning, except when the coil is unplug. during the oil change, I removed the round plate next to the oil plug by accident at the bottom. I put it back the same way.. is my flyweel loose or is it the starter solenoid? why would the solenoid come out as i am driving? |
| 914itis |
Oct 27 2010, 05:42 AM
YES IT HAS A BOLT AND AT FIRST I DID IT REAL TIGHT WITH A WRENCH, THEN AFTER HEARING THE NOISE, I TOOK IT OFF AND PUT IT BACK. i TIGHTEN IT WITH A WRENCH BUT NOT TOO TIGHT.
| 914itis |
Oct 27 2010, 07:17 AM
YES IT HAS A BOLT AND AT FIRST I DID IT REAL TIGHT WITH A WRENCH, THEN AFTER HEARING THE NOISE, I TOOK IT OFF AND PUT IT BACK. i TIGHTEN IT WITH A WRENCH BUT NOT TOO TIGHT. Can this round plate shown in this picture cause my issue. what is the function of this plate and how tight it has to be? ![]() |
ppetion Noise Oct 26 2010, 08:03 PM
hot_shoe914
I changed my oil today using 20/50 brad penn, and... Oct 26 2010, 10:01 PM
Vacca Rabite morning bump.
This guy bought a dog of an engine ... Oct 27 2010, 04:12 AM
vsg914 Did that round plate have one bolt in the center o... Oct 27 2010, 05:34 AM
SLITS If you overtightened the bolt, you could have crac... Oct 27 2010, 07:32 AM
ppetion Griding is correct not squeeking. Oct 27 2010, 07:38 AM
DNHunt
The answer to the first part of the question is ... Oct 27 2010, 07:54 AM
ppetion
The answer to the first part of the question is... Oct 27 2010, 08:54 AM
Kirmizi High-torque starter needing a shim? :idea:
Mike Oct 27 2010, 08:57 AM
ppetion gonna pickup one and start from there. I know that... Oct 27 2010, 09:09 AM
ppetion
gonna pickup one and start from there. I know tha... Oct 27 2010, 12:18 PM
ppetion
gonna pickup one and start from there. I know th... Oct 27 2010, 04:33 PM
orange914
everything is fine, but it does not start here. I... Oct 27 2010, 09:24 PM
orange914
[quote name='ppetion' post='1387569' date='Oct 27... Oct 27 2010, 10:05 PM
Drums66 ....From what you said & what you already foun... Oct 27 2010, 03:24 PM
ppetion I never say that it did not start. the car was alw... Oct 27 2010, 09:37 PM
ppetion This is not my picture. Just got the car don't... Oct 28 2010, 07:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 10:36 PM |
