> Noise, Starter or flyweel
914itis
post Oct 26 2010, 08:03 PM
I changed my oil today using 20/50 brad penn, and I changed all the gaskets for the exhaust. the exaust sounds beautiful.
My friend was helping me and I decided to take him home. After driving 5 city blocks, I heard a weird noise like the fan is touching something (squeeking). pulled over turned off the car. I try to start the car, the noise is there as the starter is spining.
Pushed the car back home, double check everything, even try to loosen the exhaust, the same thing.
The noise looks like its coming from the starter or flyweel. I removed the coil cable so the car wont start, try to start it and there was no noise. I put the cable back, the car started and the noise dissapeared. but each time i start the car i hear the noise as the starter is spinning, except when the coil is unplug.
during the oil change, I removed the round plate next to the oil plug by accident at the bottom. I put it back the same way.. is my flyweel loose or is it the starter solenoid? why would the solenoid come out as i am driving?
914itis
post Oct 27 2010, 09:09 AM
gonna pickup one and start from there. I know that the FLAPS are not the best place to get one, if anything, i will return it. at least I will have an idea
914itis
post Oct 27 2010, 12:18 PM
QUOTE(ppetion @ Oct 27 2010, 11:09 AM) *
Noise is definitely coming from flywheel / starter area. Still tryng to locate a starter. Anythng else in in that area that can be loose or torn to to make such noise?
914itis
post Oct 27 2010, 04:33 PM
QUOTE(ppetion @ Oct 27 2010, 02:18 PM) *
ok All thank you so much, the scary part is over. It was the [/size]Starter. [/color][/b][font=Arial Black][size=7]
everything is fine, but it does not start here. I think that I need carb adjustment. It runs fine but it looks like its running on a bad gas. or on 3 cyl. I still need an expert to help me set this up
ppetion   Noise   Oct 26 2010, 08:03 PM
hot_shoe914   I changed my oil today using 20/50 brad penn, and...   Oct 26 2010, 10:01 PM
Vacca Rabite   morning bump. This guy bought a dog of an engine ...   Oct 27 2010, 04:12 AM
vsg914   Did that round plate have one bolt in the center o...   Oct 27 2010, 05:34 AM
ppetion   YES IT HAS A BOLT AND AT FIRST I DID IT REAL TIGHT...   Oct 27 2010, 05:42 AM
ppetion   YES IT HAS A BOLT AND AT FIRST I DID IT REAL TIGH...   Oct 27 2010, 07:17 AM
SLITS   If you overtightened the bolt, you could have crac...   Oct 27 2010, 07:32 AM
ppetion   Griding is correct not squeeking.   Oct 27 2010, 07:38 AM
DNHunt   The answer to the first part of the question is ...   Oct 27 2010, 07:54 AM
ppetion   The answer to the first part of the question is...   Oct 27 2010, 08:54 AM
Kirmizi   High-torque starter needing a shim? :idea: Mike   Oct 27 2010, 08:57 AM
ppetion   gonna pickup one and start from there. I know that...   Oct 27 2010, 09:09 AM
ppetion   gonna pickup one and start from there. I know tha...   Oct 27 2010, 12:18 PM
ppetion   gonna pickup one and start from there. I know th...   Oct 27 2010, 04:33 PM
orange914   everything is fine, but it does not start here. I...   Oct 27 2010, 09:24 PM
orange914   [quote name='ppetion' post='1387569' date='Oct 27...   Oct 27 2010, 10:05 PM
Drums66   ....From what you said & what you already foun...   Oct 27 2010, 03:24 PM
ppetion   I never say that it did not start. the car was alw...   Oct 27 2010, 09:37 PM
ppetion   This is not my picture. Just got the car don't...   Oct 28 2010, 07:06 AM
- Lo-Fi Version Time is now: 7th December 2025 - 10:36 PM
