Stud length for 5-lug conversions??, for redrilled front rotors and rear hubs |
Mueller |
Apr 8 2003, 02:32 PM
Need to order wheel studs for my 914,
Anyone know what the minimum length stud is being used?? Fronts and rears will be re-drilled stock /4 units for now. thanks, Mike |
Mueller |
Apr 8 2003, 05:24 PM
Thanks for the info...I just needed a general size...
the 50mm figure should be fine, the studs available are 63.5mm so that should give me plenty of threads and then some. The rims are 16x7 with a 40mm offset, so I might have to run a 5mm spacer in the rear if tires are close to the inside fender well, but I don't think they will be.......... I'm sure in the front I'll want to run a larger spacer to move the wheels a little closer to the outside fender lip so that it looks correct Tire size will more than likely be 205/50/16's |
Lo-Fi Version | Time is now: 10th June 2024 - 07:28 PM |
