| 914itis |
Oct 26 2010, 08:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I changed my oil today using 20/50 brad penn, and I changed all the gaskets for the exhaust. the exaust sounds beautiful.
My friend was helping me and I decided to take him home. After driving 5 city blocks, I heard a weird noise like the fan is touching something (squeeking). pulled over turned off the car. I try to start the car, the noise is there as the starter is spining. Pushed the car back home, double check everything, even try to loosen the exhaust, the same thing. The noise looks like its coming from the starter or flyweel. I removed the coil cable so the car wont start, try to start it and there was no noise. I put the cable back, the car started and the noise dissapeared. but each time i start the car i hear the noise as the starter is spinning, except when the coil is unplug. during the oil change, I removed the round plate next to the oil plug by accident at the bottom. I put it back the same way.. is my flyweel loose or is it the starter solenoid? why would the solenoid come out as i am driving? |
| 914itis |
Oct 27 2010, 09:09 AM
gonna pickup one and start from there. I know that the FLAPS are not the best place to get one, if anything, i will return it. at least I will have an idea
| 914itis |
Oct 27 2010, 12:18 PM
gonna pickup one and start from there. I know that the FLAPS are not the best place to get one, if anything, i will return it. at least I will have an idea Noise is definitely coming from flywheel / starter area. Still tryng to locate a starter. Anythng else in in that area that can be loose or torn to to make such noise? |
| 914itis |
Oct 27 2010, 04:33 PM
gonna pickup one and start from there. I know that the FLAPS are not the best place to get one, if anything, i will return it. at least I will have an idea Noise is definitely coming from flywheel / starter area. Still tryng to locate a starter. Anythng else in in that area that can be loose or torn to to make such noise? ok All thank you so much, the scary part is over. It was the [/size]Starter. [/color][/b][font=Arial Black][size=7] everything is fine, but it does not start here. I think that I need carb adjustment. It runs fine but it looks like its running on a bad gas. or on 3 cyl. I still need an expert to help me set this up |
| orange914 |
Oct 27 2010, 09:24 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
everything is fine, but it does not start here. I think that I need carb adjustment. It runs fine but it looks like its running on a bad gas. or on 3 cyl. I still need an expert to help me set this up i would check the engine end play also, IF the soliniod pull back problem was minimal. (you confirmed that on the starter itself?) why did it only start after the oil change? it's not because you didn't use quality & heavy enough weight oil. am i wrong that this is a new to you engine? p.o. use gear oil before change? seen that. |
ppetion Noise Oct 26 2010, 08:03 PM
hot_shoe914
I changed my oil today using 20/50 brad penn, and... Oct 26 2010, 10:01 PM
Vacca Rabite morning bump.
This guy bought a dog of an engine ... Oct 27 2010, 04:12 AM
vsg914 Did that round plate have one bolt in the center o... Oct 27 2010, 05:34 AM
ppetion YES IT HAS A BOLT AND AT FIRST I DID IT REAL TIGHT... Oct 27 2010, 05:42 AM
ppetion
YES IT HAS A BOLT AND AT FIRST I DID IT REAL TIGH... Oct 27 2010, 07:17 AM
SLITS If you overtightened the bolt, you could have crac... Oct 27 2010, 07:32 AM
ppetion Griding is correct not squeeking. Oct 27 2010, 07:38 AM
DNHunt
The answer to the first part of the question is ... Oct 27 2010, 07:54 AM
ppetion
The answer to the first part of the question is... Oct 27 2010, 08:54 AM
Kirmizi High-torque starter needing a shim? :idea:
Mike Oct 27 2010, 08:57 AM
orange914
[quote name='ppetion' post='1387569' date='Oct 27... Oct 27 2010, 10:05 PM
Drums66 ....From what you said & what you already foun... Oct 27 2010, 03:24 PM
ppetion I never say that it did not start. the car was alw... Oct 27 2010, 09:37 PM
ppetion This is not my picture. Just got the car don't... Oct 28 2010, 07:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 10:37 PM |
