| 1988Hawk |
Oct 28 2010, 06:27 AM
Newbie ![]() Group: Members Posts: 41 Joined: 17-April 08 From: Chicago Member No.: 8,929 Region Association: None |
I ordered a condensor from PP for a 75 2.0L with FI. The issue I'm having is that once installed the section from the condensor to the distributor entry "plug" is very taunt, to the point where I am worried about damaging the connectivity. Has anyone esle run into this? Thanks, Jim |
| Cap'n Krusty |
Oct 28 2010, 08:49 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Or you could simply continue using the original Bosch condenser. I've seen maybe 5-6 condenser failures on VW/Porsche vehicles in 40 years of working on them on a daily basis. BTW, what part number did you use?
The Cap'n |
| 1988Hawk |
Oct 28 2010, 10:11 AM
Or you could simply continue using the original Bosch condenser. I've seen maybe 5-6 condenser failures on VW/Porsche vehicles in 40 years of working on them on a daily basis. BTW, what part number did you use? The Cap'n Cap'n Part number Bosch 02054 Distributor Condenser, 1970-76 914-4 1.7L, 2.0L #311-905-295C-M14 It is about 1/2 inch shorter vs the old one. Thanks, Jim |
1988Hawk Condensor Wire Oct 28 2010, 06:27 AM
dr914@autoatlanta.com no should fit fine I am sure that you mounted the ... Oct 28 2010, 08:28 AM
76-914 They didn't waste any wire there, did they? It... Oct 28 2010, 08:29 AM
Drums66
They didn't waste any wire there, did they? I... Oct 28 2010, 11:26 AM
realred914 Install a Pertronix and never mess with points and... Oct 28 2010, 09:03 AM
windforfun My Bosche condenser wire was so long that I had to... Oct 28 2010, 12:10 PM
Cap'n Krusty Where's your coil mounted?
The Cap'n Oct 28 2010, 12:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 12:26 PM |
