| 1988Hawk |
Oct 28 2010, 06:27 AM
Newbie ![]() Group: Members Posts: 41 Joined: 17-April 08 From: Chicago Member No.: 8,929 Region Association: None |
I ordered a condensor from PP for a 75 2.0L with FI. The issue I'm having is that once installed the section from the condensor to the distributor entry "plug" is very taunt, to the point where I am worried about damaging the connectivity. Has anyone esle run into this? Thanks, Jim |
| 76-914 |
Oct 28 2010, 08:29 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,825 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
They didn't waste any wire there, did they? It's close. When the points need to be changed switch over to Petronix solid state (<$70) and eliminate that problem.
| Drums66 |
Oct 28 2010, 11:26 AM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
They didn't waste any wire there, did they? It's close. When the points need to be changed switch over to Petronix solid state (<$70) and eliminate that problem. ...Yeah, teach them a lesson....don't buy anymore?? (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/bye1.gif) |
1988Hawk Condensor Wire Oct 28 2010, 06:27 AM
dr914@autoatlanta.com no should fit fine I am sure that you mounted the ... Oct 28 2010, 08:28 AM
Cap'n Krusty Or you could simply continue using the original Bo... Oct 28 2010, 08:49 AM
1988Hawk
Or you could simply continue using the original B... Oct 28 2010, 10:11 AM
realred914 Install a Pertronix and never mess with points and... Oct 28 2010, 09:03 AM
windforfun My Bosche condenser wire was so long that I had to... Oct 28 2010, 12:10 PM
Cap'n Krusty Where's your coil mounted?
The Cap'n Oct 28 2010, 12:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 12:22 PM |
