slu234 |
Member ![]() ![]() Group: Members Posts: 57 Joined: 20-January 09 From: Staunton, VA Member No.: 9,949 Region Association: MidAtlantic Region ![]() |
I am replacing all the bushings in my tail shifter linkage but had problems at the shifter balls (#53 in the schematic).
How are they removed? Didn't want to damage anything else in the process. Thanks, Brian ![]() |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
Many of them are stuck in there, some with a vacuum behind the plastic cup if the vent hole is plugged. It's an easy fix.
Solidly mount the shift lever, like in a vice with aluminum jaws or something to protect the shaft, Then don protective goggles and gloves and firmly hold the ball-socket. Blow compressed air into the vent hole. It'll pop right out. Then separate the ball from it's plastic cup. Lubricate it, replace the cup and stick it back in there. I like silicon lube. Dooop... wrong piece, sorry. Oh well somebody didn't know this. |
Lo-Fi Version | Time is now: 1st July 2025 - 07:36 AM |
