> AN fitting vs fuel line size?
stugray
post Nov 14 2010, 10:35 PM
I want to buy a fuel cell.
It says that it has:
10AN Male inlet
8AN Male rollover
8AN Male return
http://www.jegs.com/i/JEGS/555/15551/10002/-1
When I try to lookup AN fittings vs. fuel line size I find:
-3AN - 3/8" ID
-4AN - 7/16" ID
-6AN - 9/16" ID
-8AN - 3/4" ID
-10AN - 7/8" ID
So .... are they saying I need fuel lines that are 3/4" ID?????
That is ridiculous. I have a coil of braided stainless hose that is ~5/16 ID.
It seems like the logical size for fuel line, so that seems like -3AN to me.
Why would the fuel lines be so large from the fuel cell?
Seems like a lot of expensive adapters for two tiny lines through my tunnel.
(IMG:style_emoticons/default/WTF.gif)
Any help would be good.
I must be missing something ......
And I suppose the "10AN Inlet" is for the feed to the fuel pump/pressure-regulator and the "8AN return" is the dump line back from the pressure reg.?
Stu
jasons
post Nov 14 2010, 11:41 PM
Jackstand Extraordinaire
The AN sizes you cross referenced are wrong. As already stated just divide by 16. Example, your 5/16 roll of hose is -5 AN.
And, you posted a link to just the cap assembly. If you look at the actual fuel cells listed by Jegs, most have a -8 AN outlet which is 1/2 inch (8/16).
Curious, why do you want a fuel cell?
stugray   AN fitting vs fuel line size?   Nov 14 2010, 10:35 PM
strawman   AN sizing is pretty straightforward: take the numb...   Nov 14 2010, 11:05 PM
jasons   The AN sizes you cross referenced are wrong. As a...   Nov 14 2010, 11:41 PM
stugray   Thanks for that! It makes sense now (never tr...   Nov 14 2010, 11:42 PM
jasons   I'm not sure I can answer your question, but I...   Nov 15 2010, 12:03 AM
ArtechnikA   So should I run 8-AN (1/2" ID steel braided ...   Nov 15 2010, 04:36 AM
ME733   ....Unless you are running fuel injection....you w...   Nov 15 2010, 05:43 AM
pcar916   -6AN will be fine. I'm using it for my return ...   Nov 15 2010, 09:50 AM
stugray   Ok, Thanks for all the help. Brant came over and...   Nov 18 2010, 05:12 PM
jd74914   Sorry to rain on your parade but you're plan d...   Nov 18 2010, 09:18 PM
GeorgeRud   :agree: The braided lines look nice, but don...   Nov 18 2010, 09:51 PM
ArtechnikA   :agree: The braided lines look nice, but don...   Nov 18 2010, 10:07 PM
Rotary'14   If you decide to use rubber hose fuel line,, be su...   Nov 18 2010, 10:05 PM
campbellcj   I went with metal tube thru the tunnel with proper...   Nov 18 2010, 11:40 PM
stugray   Ok, so I have done the following: Verified that I...   Dec 20 2010, 02:21 PM
stugray   For the tubing experts out there... Can I do this:...   Dec 21 2010, 07:46 AM
ArtechnikA   Flare using a single flare tool. Yes, as long as ...   Dec 21 2010, 09:02 AM
stugray   ArtechnikA, Thanks for the reply. The 3/8" ...   Dec 21 2010, 10:08 AM
- Lo-Fi Version Time is now: 8th July 2025 - 08:45 PM
