stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I want to buy a fuel cell.
It says that it has: 10AN Male inlet 8AN Male rollover 8AN Male return http://www.jegs.com/i/JEGS/555/15551/10002/-1 When I try to lookup AN fittings vs. fuel line size I find: -3AN - 3/8" ID -4AN - 7/16" ID -6AN - 9/16" ID -8AN - 3/4" ID -10AN - 7/8" ID So .... are they saying I need fuel lines that are 3/4" ID????? That is ridiculous. I have a coil of braided stainless hose that is ~5/16 ID. It seems like the logical size for fuel line, so that seems like -3AN to me. Why would the fuel lines be so large from the fuel cell? Seems like a lot of expensive adapters for two tiny lines through my tunnel. (IMG:style_emoticons/default/WTF.gif) Any help would be good. I must be missing something ...... And I suppose the "10AN Inlet" is for the feed to the fuel pump/pressure-regulator and the "8AN return" is the dump line back from the pressure reg.? Stu |
stugray |
Thanks for that!
It makes sense now (never trust a quick web search). So should I run 8-AN (1/2" ID steel braided hose) through my tunnel, or convert the AN fitting to stainless flare before going through? I plan on moving the fuel pump to the front since I removed the tank, but I still need two lines from the tank to the engine bay for the pressure regulator, right? "Curious, why do you want a fuel cell?" Vintage racing (SCCA rules) Stu |
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
I'm not sure I can answer your question, but I thought I would point out... Chris at Tangerine Racing sells stainless steel tunnel lines and has an option to weld AN fittings on them.
http://www.tangerineracing.com/stainlessFuelLines.htm I asked about the fuel cell because my project car came with a brand new Fuel Safe and I'm on the fence about its future. (I'm not trying to sell it, just curious what your motivation was). |
Lo-Fi Version | Time is now: 8th July 2025 - 09:46 PM |
