> Bell crank and throttle linkage for 3.2 liter DME conversion
bluhun
post Nov 15 2010, 08:58 PM
Where can I obtain bell crank, throttle linkage cables, rods, etc for a 3.2 liter DME conversion car?
I used the James Patrick throttle linkage kit, which eliminates the bell crank, uses a much shorter cable, and routes the throttle cable in close proximity to the heat exchangers. It's a much simpler system, but the problem is that when you get caught in a traffic jam and sit around idling for a half hour or so the throttle cable fries for lack of cooling air flow and the car becomes undrivable.
dion9146
post Nov 16 2010, 06:42 PM
Did you guys use the stock 914-4 (or 6) throttle cable? And did you route it under the engine with any heat shielding or protection?
I'm using a standard bellcrank and stick on my 3.2 conversion, and although it works fine, I'm a big believer in making things more simple and eliminating potential defects. (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 01:25 PM
