Side mirrors, one or two |
Niklas |
Nov 14 2010, 03:27 AM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Hello!
Should 914 have one ore two side mirrors ? Niklas |
Niklas |
Nov 14 2010, 09:22 AM
Was it standard with both sides in any country ( sweden ) ?
Pat Garvey |
Nov 14 2010, 07:54 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Was it standard with both sides in any country ( sweden ) ? I can tell you only this - thr late 72 US passenger doors were equipped with welded nuts inside the door for fitting a second mirror. All you needed to do was drill a hole, get a right side mirror (or fklip the left side) and mount. Though I would appreciate the extra mirror, I won't drill holes in my my 914. Anal? Yep. Pat |
Tom_T |
Nov 16 2010, 06:30 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Was it standard with both sides in any country ( sweden ) ? I can tell you only this - thr late 72 US passenger doors were equipped with welded nuts inside the door for fitting a second mirror. All you needed to do was drill a hole, get a right side mirror (or fklip the left side) and mount. Though I would appreciate the extra mirror, I won't drill holes in my my 914. Anal? Yep. Pat Pat & Niklas - those holes were on all passenger side doors 70-76 MYs. Many of us other than Pat put them on the passenger side door for safety's sake - & to keep our 914's in one piece while driving ~ hopefully. (IMG:style_emoticons/default/dry.gif) Since it was factory standard in some markets & an available option from dealers or for a factory ordered 914, adding them should not cause one to be gigged/docked CW points IMHO. IIRC it was Sweden & 1 or 2 other markets where the pass. side mirrors were required which prompted the Porsche/VW JV to set-up the R doors to accept them & to make the very slightly convex R-side mirror (still available). However, be aware that the metal mirror housings are the same on both sides & the part no. stamped into it will be upside down on the passenger one, so the only way to tell which is which is literally to look in them both together side-by-side & see which shows your face bigger (& uglier in my case! (IMG:style_emoticons/default/biggrin.gif) ) & that's the R-side one with the slight convex effect. I had to do that when I ordered 2 new ones for my resto last year, & thought that I got the wrong one sent for the R-side! Niklas - if you've bought 4 new L mirrors for those 2 914s - then you may want to try to exchange the 2 right side ones for the proper convex ones from whomever you bought them originally (dealer, AA, PP/Automotion, etc.), since they're still available new in R-side convex from Porsche. |
MDG |
Nov 16 2010, 07:19 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Lo-Fi Version | Time is now: 7th June 2024 - 07:49 AM |
