> AN fitting vs fuel line size?
stugray
post Nov 14 2010, 10:35 PM
I want to buy a fuel cell.
It says that it has:
10AN Male inlet
8AN Male rollover
8AN Male return
http://www.jegs.com/i/JEGS/555/15551/10002/-1
When I try to lookup AN fittings vs. fuel line size I find:
-3AN - 3/8" ID
-4AN - 7/16" ID
-6AN - 9/16" ID
-8AN - 3/4" ID
-10AN - 7/8" ID
So .... are they saying I need fuel lines that are 3/4" ID?????
That is ridiculous. I have a coil of braided stainless hose that is ~5/16 ID.
It seems like the logical size for fuel line, so that seems like -3AN to me.
Why would the fuel lines be so large from the fuel cell?
Seems like a lot of expensive adapters for two tiny lines through my tunnel.
(IMG:style_emoticons/default/WTF.gif)
Any help would be good.
I must be missing something ......
And I suppose the "10AN Inlet" is for the feed to the fuel pump/pressure-regulator and the "8AN return" is the dump line back from the pressure reg.?
Stu
Rotary'14
post Nov 18 2010, 10:05 PM
If you decide to use rubber hose fuel line,, be sure to use "SAE 30R9" commonly referred to as Fuel Injection fuel line, even if you're using carbs. The reasoning behind this is the new formulations of fuel will eat through regular fuel line, and some lesser steel braided hose.
There was some discussion on this other thread,,,
http://www.914world.com/bbs2/index.php?sho...mp;hl=fuel+line
I hope this helps,,
-Robert
stugray   AN fitting vs fuel line size?   Nov 14 2010, 10:35 PM
strawman   AN sizing is pretty straightforward: take the numb...   Nov 14 2010, 11:05 PM
jasons   The AN sizes you cross referenced are wrong. As a...   Nov 14 2010, 11:41 PM
stugray   Thanks for that! It makes sense now (never tr...   Nov 14 2010, 11:42 PM
jasons   I'm not sure I can answer your question, but I...   Nov 15 2010, 12:03 AM
ArtechnikA   So should I run 8-AN (1/2" ID steel braided ...   Nov 15 2010, 04:36 AM
ME733   ....Unless you are running fuel injection....you w...   Nov 15 2010, 05:43 AM
pcar916   -6AN will be fine. I'm using it for my return ...   Nov 15 2010, 09:50 AM
stugray   Ok, Thanks for all the help. Brant came over and...   Nov 18 2010, 05:12 PM
jd74914   Sorry to rain on your parade but you're plan d...   Nov 18 2010, 09:18 PM
GeorgeRud   :agree: The braided lines look nice, but don...   Nov 18 2010, 09:51 PM
ArtechnikA   :agree: The braided lines look nice, but don...   Nov 18 2010, 10:07 PM
Rotary'14   If you decide to use rubber hose fuel line,, be su...   Nov 18 2010, 10:05 PM
campbellcj   I went with metal tube thru the tunnel with proper...   Nov 18 2010, 11:40 PM
stugray   Ok, so I have done the following: Verified that I...   Dec 20 2010, 02:21 PM
stugray   For the tubing experts out there... Can I do this:...   Dec 21 2010, 07:46 AM
ArtechnikA   Flare using a single flare tool. Yes, as long as ...   Dec 21 2010, 09:02 AM
stugray   ArtechnikA, Thanks for the reply. The 3/8" ...   Dec 21 2010, 10:08 AM
- Lo-Fi Version Time is now: 8th July 2025 - 09:01 PM
