stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I want to buy a fuel cell.
It says that it has: 10AN Male inlet 8AN Male rollover 8AN Male return http://www.jegs.com/i/JEGS/555/15551/10002/-1 When I try to lookup AN fittings vs. fuel line size I find: -3AN - 3/8" ID -4AN - 7/16" ID -6AN - 9/16" ID -8AN - 3/4" ID -10AN - 7/8" ID So .... are they saying I need fuel lines that are 3/4" ID????? That is ridiculous. I have a coil of braided stainless hose that is ~5/16 ID. It seems like the logical size for fuel line, so that seems like -3AN to me. Why would the fuel lines be so large from the fuel cell? Seems like a lot of expensive adapters for two tiny lines through my tunnel. (IMG:style_emoticons/default/WTF.gif) Any help would be good. I must be missing something ...... And I suppose the "10AN Inlet" is for the feed to the fuel pump/pressure-regulator and the "8AN return" is the dump line back from the pressure reg.? Stu |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,632 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
I went with metal tube thru the tunnel with proper adapters to AN braided on both ends. It was more expensive and more work but is as close as possible to a 'permanent' solution IMO.
Lo-Fi Version | Time is now: 8th July 2025 - 08:40 PM |
