> Fuel pump poll - for 3.0 with Webers, What are you using?
moparrob
post Nov 23 2010, 10:40 AM
So I am converting my '74 914 to a 3.0 with Webers and am going to run a fuel pump in the engine bay. The PO had the car set up with a big 4 running Motec injection using 3/8 aluminum fuel line setup running from the tank to the engine bay with a return line to the tank. There are presently two AN-6 bulkhead fittings which exit just below the battery tray which I will be connecting to.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1290530412.1.jpg)
I'm looking for suggestions on a make and model of a fuel pump to run as well as suggestions for mounting. There is an unused mounting bracket near the fittings which could be easily modified to mount fuel pump. My concern is that it does not interfere with the engine or be located too close for heat reasons. So that is a possibility.
I'm looking for a good pump that will run fairly quietly and will last a long time.
Any suggestions?
Thanks.
Justinp71
post Nov 24 2010, 09:31 AM
I have a 3.0 with webbers aswell, I got the CB performance fuel pump and mounted it upfront (since thats where it was from factory on my 75). Works great, very quiet and fairly inexpensive. Dont need a regulator, but I put one on anyways. You'll need the 3.5psi model.
http://www.cbperformance.com/catalog.asp?ProductID=577
moparrob   Fuel pump poll - for 3.0 with Webers   Nov 23 2010, 10:40 AM
Mark Henry   You only need one line and a low pressure pump. Ma...   Nov 23 2010, 11:17 AM
Cap'n Krusty   The pump needs to be lower than the tank. Forget ...   Nov 23 2010, 11:23 AM
pcar916   I like Facet and the interrupter pump will be the ...   Nov 23 2010, 11:54 AM
jt914-6   I've got a 3.0 with webers and mounted my pump...   Nov 23 2010, 03:47 PM
Scott Schroeder   regulator/pressure gauge. I was just working ...   Dec 6 2010, 11:12 AM
campbellcj   I have a Holley Red up front, with a big metal Can...   Nov 24 2010, 12:36 AM
Cap'n Krusty   Not to change the subject too much, but I suggest ...   Nov 24 2010, 12:51 AM
Justinp71   I have a 3.0 with webbers aswell, I got the CB per...   Nov 24 2010, 09:31 AM
moparrob   Thanks for all the great responses guys. I guess t...   Nov 24 2010, 08:06 PM
jt914-6   The fuel pump I'm using draws about 1.5 amp. I...   Nov 24 2010, 08:32 PM
rfuerst911sc   I'm also using the CB Performance fuel pump. I...   Nov 25 2010, 07:14 AM
Van914   I used a Holly Blue pump on my conversion. Mounted...   Nov 25 2010, 07:37 AM
GeorgeRud   I also used the rotary (Pierburg?) pump mounted up...   Nov 25 2010, 08:53 AM
moparrob   Hmmm, good idea on the switch George. That might a...   Nov 26 2010, 01:15 AM
GeorgeRud   You can probably find an original foglight or rear...   Nov 26 2010, 02:22 PM
Mark Henry   You can probably find an original foglight or rea...   Nov 26 2010, 03:35 PM
Al Meredith   Whereas the carbs only need one fuel line: I usual...   Nov 26 2010, 05:59 PM
moparrob   Hmmm. Very interesting. I have a 3/8 return line...   Nov 26 2010, 08:37 PM
Eric_Shea   Rob... this may give you an idea: http://www.914w...   Nov 27 2010, 06:22 PM
moparrob   Wow, that's really clean Eric. Did you just gr...   Nov 27 2010, 06:49 PM
Eric_Shea   Thanks Rob, There's a ground buss behind the ...   Nov 27 2010, 08:01 PM
9146986   I've done several fuel pump relocations to the...   Nov 28 2010, 11:03 AM
jt914-6   I've done several fuel pump relocations to th...   Nov 29 2010, 07:09 AM
Scott Schroeder   Are there any keyed power leads up front? I found ...   Nov 28 2010, 11:11 AM
Eric_Shea   Lines came in today... Hardlines: http://www.91...   Dec 4 2010, 12:41 AM
moparrob   Nice setup Eric. Is the hard line going to protru...   Dec 4 2010, 04:15 AM
Eric_Shea   Yes, they come through the holes shown before. ...   Dec 4 2010, 09:49 AM
brant   since you already have a return line, I'd sugg...   Dec 4 2010, 10:49 AM
Eric_Shea   Isn't the return line fed off the pump which w...   Dec 4 2010, 12:25 PM
moparrob   Yep. The supply and return lines are already plum...   Dec 5 2010, 12:40 AM
Eric_Shea   Yes, the brass lines come through the hole by the ...   Dec 5 2010, 07:04 PM
Eric_Shea   Still confused about the pump. If it's up fro...   Dec 5 2010, 07:09 PM
brant   I'm not really familiar with the stock -6 fuel...   Dec 5 2010, 09:22 PM
brant   pictures:   Dec 5 2010, 09:24 PM
brant   and   Dec 5 2010, 09:25 PM
moparrob   I'll be using "Option B" from the di...   Dec 5 2010, 09:52 PM
brant   I'll be using "Option B" from the d...   Dec 6 2010, 12:08 AM
Eric_Shea   I thought stock -6 pumps were set at a certain pre...   Dec 5 2010, 10:12 PM
brant   I thought stock -6 pumps were set at a certain pr...   Dec 6 2010, 12:20 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:15 AM
