| dbgriffith75 |
Sep 16 2008, 04:08 PM
TheGrif ![]() ![]() ![]() Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
So basically I'm just curious here on who's opinion is what and why. I might have seen a similar post a while back but I don't remember for sure.
My personal opinion is carbs. I don't know what a new injector for a 914 is going for but generally speaking carb kits are cheaper than new injectors. Plus, I like trying to fine tune carbs- if one is set right the engine can be extremely efficient. My teener is set up for carbs and I plan to leave it that way. |
| ME733 |
Nov 28 2010, 09:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
I voted for Carburators...........here,s why....The stock fuel injection is a first generation system., with limitations..With carburators you are NOT restrained within certain parameters for a camshaft choise., with fuel injection the duration and lift is limited as a practial matter., Carburators are a demand system.The more air and fuel the engine needs the carburator (s) will supply it no matter what RPM,s you use.....Camshaft selection is just a matter of the RPM ranges you intend to use...Carburators are simpler.(KISS). keep it simple stupid. Carburators are simpler, without the masses of high pressure fuel lines , fittings, temp senders,air box, air flow meter,etc etc...Over many years I have replaced the fuel injection systems with carburators.Every customer was satisfied and the engine ran better, had MORE HP. and was customer friendly....The OEM fuel injection is adequate for the limited power range and RPM,s in stock form., but after forty years practacially every component is worn out, and some of the replacement parts are getting EXPENSIVE...The OEM system, to me, is just not worth the hassle of maintenance....Carburators are the way to go.
dbgriffith75 Carbs VS FI Sep 16 2008, 04:08 PM
melnyk
So basically I'm just curious here on who... Sep 16 2008, 04:43 PM
BarberDave :trophy:
I have Carbs, i like them. How ever ... Sep 16 2008, 04:57 PM
Lavanaut Try a search...
http://www.914world.com/bbs2/inde... Sep 16 2008, 05:03 PM
jasons I :wub: DJET! When its properly set up, it... Sep 16 2008, 05:08 PM
jd74914 My L-Jet car runs great. :D
On a side note, I... Sep 16 2008, 05:11 PM
vsg914 Jeez, here we go again. Sep 16 2008, 05:57 PM
So.Cal.914 Why?..Cause. :)
Sep 16 2008, 06:01 PM
scotty b
Why?..Cause. :)
God I hope that's just d... Sep 16 2008, 07:30 PM
type47 FI because it was factory installed
FI because it ... Sep 16 2008, 06:07 PM
toon1 FI is better unless you like carbs, then carbs. ar... Sep 16 2008, 06:11 PM
So.Cal.914 Carbs because they sound Great. :)
Carbs because... Sep 16 2008, 06:14 PM
Todd Enlund I voted FI because it is infinitely more tunable. ... Sep 16 2008, 06:28 PM
r_towle I would say this.
Preface...I have a Djet and and ... Sep 16 2008, 06:34 PM
EyeTrip
Modern FI would be my choice, something with an ... Sep 16 2008, 06:54 PM
EyeTrip Love the sound of dual webers
Once setup, carbs ar... Sep 16 2008, 06:52 PM
Bleyseng
Once setup, carbs a... Sep 16 2008, 07:25 PM
vsg914
Once setup, carbs ... Sep 16 2008, 08:20 PM
vsg914 Edit: delete accidental double post. Damn fat fing... Sep 16 2008, 08:21 PM
EyeTrip
[quote name='EyeTrip' post='1080266... Sep 17 2008, 03:39 AM
dbgriffith75
the TPS and MPS are NLA!
the TPS and MPS are... Sep 16 2008, 06:53 PM
azbill FI is the way to go. I'm running the Emerald M... Sep 16 2008, 07:00 PM
dflesburg We have two 1970 cars both with 2.0 motors, one wi... Sep 16 2008, 08:27 PM
So.Cal.914
That should be spelt BLOW
With the FI that came ... Sep 16 2008, 08:35 PM
vsg914
With the FI that came... Sep 16 2008, 08:53 PM
Bleyseng
With the FI that cam... Sep 16 2008, 10:42 PM
Dave_Darling Which is better?
Yes--yes they are.
Really, what... Sep 16 2008, 09:09 PM
So.Cal.914 With what I put into that FI it should have levita... Sep 16 2008, 11:30 PM
Justinp71 I like carbs because I'm mechanical... but whe... Sep 16 2008, 11:53 PM
Rand My FI starts promptly, idles flawlessly, and runs ... Sep 16 2008, 11:54 PM
Bleyseng I'll be running carbs on the next engine, 2.4L... Sep 17 2008, 08:47 AM
Mark Henry I voted FI, but d and L-jet sucks....SDS baby
I... Sep 17 2008, 01:44 PM
Cevan
I... Sep 17 2008, 02:27 PM
DBCooper If you're going to compare then you need to co... Sep 17 2008, 04:13 PM
Carbs VS FI, Which is better?
No ... Sep 17 2008, 07:06 PM
SGB I like carbs because people talk about "good ... Sep 17 2008, 07:45 PM
So.Cal.914 For all of you that think injection is the best, I... Sep 17 2008, 08:27 PM
749142 fi becuase,
better gas mpg
its original,
and setu... Sep 17 2008, 08:32 PM
DBCooper Pro Systems, you mean the drag-racing carburetor m... Sep 17 2008, 08:58 PM
Spoke I like FI because I could sell my used dual Weber ... Sep 17 2008, 09:57 PM
Mark Henry Now if your happy with a stock 80/95hp L/D-jet eng... Sep 17 2008, 10:01 PM
So.Cal.914
Now if your happy with a stock 80/95hp L/D-jet en... Sep 18 2008, 06:01 PM
DBCooper
I do have a preference like alot of others here, ... Sep 18 2008, 07:09 PM
DBCooper That's why I said a stock engine, that's w... Sep 17 2008, 10:36 PM
So.Cal.914
I drive mine FT quite often, I built my engine t... Sep 17 2008, 10:58 PM
DBCooper Great, like everything else on your car, do what y... Sep 17 2008, 11:36 PM
LarryR I think you needed a 3rd category aftermarket fuel... Sep 17 2008, 11:39 PM
dw914er I voted FI. It workes great, and is pretty reliabl... Sep 17 2008, 11:44 PM
vsg914 See? One more useless thread about FI vs carbs. To... Sep 18 2008, 08:00 AM
Mark Henry
See? One more useless thread about FI vs carbs. T... Sep 18 2008, 08:18 AM
DBCooper
Most peeps who hate carb's never had a clue o... Sep 18 2008, 09:15 AM
carcam I'm new and like this thread. What's PMO?... Sep 18 2008, 10:50 AM
DBCooper They're modern upscale carburetors: http://ww... Sep 18 2008, 03:56 PM
J P Stein As the Canuck says, PEFI makes more power (& t... Sep 18 2008, 06:34 PM
nsr-jamie Didn't the Euro 1.8 models come with carbs ins... Nov 25 2010, 05:54 AM
Bleyseng
Didn't the Euro 1.8 models come with carbs in... Nov 26 2010, 06:16 AM
underthetire I voted FI, not stock, but I love to diagnose thro... Nov 25 2010, 10:26 AM
JmuRiz FI is the best, but I'm thinking more EFI...bu... Nov 25 2010, 08:50 PM
speed metal army I voted FI,Its predictable,and performs well.I als... Nov 25 2010, 09:12 PM
914 shifter up to 2056 original d-jet. :shades2: bigger displa... Nov 26 2010, 05:57 AM
benalishhero I've had three different set-ups on my stock 2... Nov 28 2010, 08:03 AM
J P Stein Dueling carbs is a very common occurance around he... Nov 28 2010, 08:29 AM
Jake Raby I provide engines with stock FI, programmable FI a... Nov 28 2010, 10:08 AM
Gint Yikes... Just when you thought that the only thin... Nov 28 2010, 10:59 AM
hashagen7 I will gladly trade this for your carbs. Nov 28 2010, 03:17 PM
Drums66
.....N... Nov 29 2010, 05:26 PM
chrisg Maybe slightly off topic, but has anybody had prob... Nov 28 2010, 09:12 PM
'73-914kid I was having the same problem for a while.. It... Nov 28 2010, 09:20 PM
tradisrad I like my d-jet set up. No cold start issues, star... Nov 29 2010, 09:56 AM
benalishhero Chrisg, does CA have E10? We run it up in Maine. N... Nov 29 2010, 10:10 AM
Dave_Darling
Evidently we do, as o... Jun 5 2011, 12:14 AM
ewdysar Carbs are inherently better. That's why all m... Jun 5 2011, 02:31 AM
ConeDodger I voted for fuel injection...
There is nothing w... Jun 5 2011, 08:04 AM
SLITS And the debate goes on and on and on and on ....
... Jun 5 2011, 09:31 AM
patssle
And I do! I get 14 mpg in city driving with ... Jun 5 2011, 09:46 AM
76-914 FI baby. Why? ... Jun 5 2011, 10:12 AM
SirAndy Carbs VS FI, Which is better?
Yes ... :D Jun 5 2011, 09:54 PM
al weidman I'm an old guy and I would say it depends on e... Jun 6 2011, 10:07 AM
Elliot Cannon
I'm an old guy and I would say it depends on ... Jun 6 2011, 02:15 PM
Bleyseng Well, after buying my 76 914 2.0l with Dell 40... Jun 6 2011, 12:13 PM
CrashDown
Carbs are inherently better. That's why all ... Jun 7 2011, 07:49 AM
Dave_Darling
I have Redline 40's on my 914. i commute 50 m... Jun 8 2011, 12:21 AM
ewdysar
Carbs are inherently better. That's why all... Jun 8 2011, 12:50 AM
Bleyseng $1000 to rebuild at YOUR COST at your work? W... Jun 7 2011, 09:57 AM
jzdu If anyone is scrapping their D-jet, I need the aux... Jun 8 2011, 04:26 PM
PRS914-6 Well, the poll only asks FI vs. carbs so general q... Aug 7 2011, 09:18 PM
GeorgeRud :agree:
though I love the look of my Webers, PRS... Sep 6 2011, 07:51 AM
stugray Just curious then:
Why was the 914-6 GT racing car... Sep 6 2011, 12:32 PM
Dave_Darling
Just curious then:
Why was the 914-6 GT racing ca... Feb 15 2012, 04:55 PM
914_teener
Just curious then:
Why was the 914-6 GT racing c... Feb 15 2012, 09:09 PM
FourBlades EFI for a daily driver because of its sealed fuel ... Sep 6 2011, 03:09 PM
Robert21 It will be eight years with my 914 2.0 Had t... Feb 15 2012, 10:50 AM
gil914 F.I. any day. My WRX has fully programmable stock ... Feb 15 2012, 12:58 PM
reharvey [quote name='gil914' date='Feb 15 2012... Feb 15 2012, 03:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:18 AM |
