biker bob |
Member ![]() ![]() Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region ![]() |
Since installing a compufire module my plugs are fouling. The spark coming thru the plug is yellow (not blue) and seems to rotate around the electrode before discharging to the tip. Firing from different points on the electrode. Can this be right? Suggestions please.
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Are you using platinum plugs? I use the compufire and blue coil without problems. Also make sure your coil has full voltage on the + terminal.
biker bob |
Lo-Fi Version | Time is now: 10th June 2024 - 12:11 PM |
