Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
Hi All,
Is there a keyed power source in the front trunk? Wipers or fresh air blower maybe? I want to relocate my fuel pump. When I pulled the motor, I found that the existing pump was wired to the coil! Very well hidden splice.... I no longer have a relay board, so I am not sure where to grab power. Thanks! Scott S |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
You can connect to the fuse panel. The stock wiring passes through the bulkhead behind the brake fluid reservoir. Very easy to slide another 18g wire through there.
IMHO, a piggyback connection on the fuse panel is acceptable, whereas a random splice from some unassociated component isn't. I'm nitpicky though. |
Lo-Fi Version | Time is now: 11th June 2024 - 01:18 AM |
