How does this come out?, Dash Plate-WTF |
ellisor3 |
Dec 7 2010, 08:02 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I am trying to remove the dash trim plate around the front of the dash to make a template. I have it removed everywhere except arount the cigarette lighter. It looks like there is some type of crush ring behind the lighter. How do you get this off?? I tried pulling it straight out but it will not move.
(IMG:style_emoticons/default/WTF.gif) |
r_towle |
Dec 7 2010, 09:07 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if you have already removed the heater controls, and I mean removed all the way...you can come at it from that hole with a screw driver...a bit easier than laying on your back trying to reach up there and do it.
I have also found that if you grab the back of the lighter and push it out, while rocking it side to side it will move that washer slowly. Its one of those one way washers with teeth that go on, but dont come off. If you manage to apply the right pressure, the teeth flip in the other direction...not all at the same time, but rocking it, twisting it, and pushing all at the same time does the trick. Now that I think about it...I think I used a long screw driver and a hammer to tap the teeth so they loosen up...you end up wrecking the washer a bit, but you can bend it back later once its out of the car. Rich |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:06 AM |
