Taco plate leak - Need you help / inside, Did you have the same issue?? |
draganc |
Dec 9 2010, 02:45 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi everybody,
I’m having a leak issue at the taco place and was wondering if you have some advice or experienced similar issue. It appears that the plate leaks only in one area – see picture. The engine has been sitting on my work bench for a few months after rebuild, hence is leaking even at cold temp. - I checked the plate on a mirror and it appears to be flat and the overall condition looks very good – no nicks nor bents or scratches at the sealing surface. - New o-ring and copper washer have been installed. - The M6x10 hex screws have been tighten to spec. - The crank opening measures 84.2mm, the taco plate’s o-ring surface measures 76mm and the o-ring is 4mm thick. It takes only a little bit of force to put the plate in place with mounted o-ring and it appears that plate is already touching the crank-case w/o torquing down the screws. Any ideas or suggestions? Thanks, Dragan |
yeahmag |
Dec 9 2010, 06:03 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
The cover is not an issue here... I'd get new copper washers and o-ring and redo the job using Loctite 565 on the o-ring. It's the same stuff that Jake Raby uses on pushrod tube o-rings.
At least that's what I did and mine is dry as a bone... While you have the plate out inspect it for burs that could nic the o-ring. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:59 AM |
