Taco plate leak - Need you help / inside, Did you have the same issue?? |
draganc |
Dec 9 2010, 02:45 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi everybody,
I’m having a leak issue at the taco place and was wondering if you have some advice or experienced similar issue. It appears that the plate leaks only in one area – see picture. The engine has been sitting on my work bench for a few months after rebuild, hence is leaking even at cold temp. - I checked the plate on a mirror and it appears to be flat and the overall condition looks very good – no nicks nor bents or scratches at the sealing surface. - New o-ring and copper washer have been installed. - The M6x10 hex screws have been tighten to spec. - The crank opening measures 84.2mm, the taco plate’s o-ring surface measures 76mm and the o-ring is 4mm thick. It takes only a little bit of force to put the plate in place with mounted o-ring and it appears that plate is already touching the crank-case w/o torquing down the screws. Any ideas or suggestions? Thanks, Dragan |
draganc |
Dec 9 2010, 08:19 PM
Thanks for the tips guys!
I checked the screws and they don't bottom out w/o the plate. I thought about using Loctite 565 (I searched Jake's posts about it), however, I'd like to understand first why it's leaking. And yes, I put the "rim" on the mirror and good point about the dimples at the mounting hols. I'll take the plate of and will post a picture of it. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:47 AM |
