Taco plate leak - Need you help / inside, Did you have the same issue?? |
draganc |
Dec 9 2010, 02:45 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi everybody,
I’m having a leak issue at the taco place and was wondering if you have some advice or experienced similar issue. It appears that the plate leaks only in one area – see picture. The engine has been sitting on my work bench for a few months after rebuild, hence is leaking even at cold temp. - I checked the plate on a mirror and it appears to be flat and the overall condition looks very good – no nicks nor bents or scratches at the sealing surface. - New o-ring and copper washer have been installed. - The M6x10 hex screws have been tighten to spec. - The crank opening measures 84.2mm, the taco plate’s o-ring surface measures 76mm and the o-ring is 4mm thick. It takes only a little bit of force to put the plate in place with mounted o-ring and it appears that plate is already touching the crank-case w/o torquing down the screws. Any ideas or suggestions? Thanks, Dragan |
realred914 |
Dec 10 2010, 09:29 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
try another plate, maybe it is bent? you should not need glue on the o-ring, o-rings are actually designed to move a bit as things expand/contract, glue can compromise that. me thinks something is bent on yours. one photos appear to show a lop sided plate where you can see the o-ring more on one side verses the othes.
good luck also PS you might try coloring the o-ring with a flet pen marker, then assemble, them take apart and see if the color might show where teh contact is not being made??? just a might help you see where the defect is. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:57 AM |
