Taco plate leak - Need you help / inside, Did you have the same issue?? |
draganc |
Dec 9 2010, 02:45 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi everybody,
I’m having a leak issue at the taco place and was wondering if you have some advice or experienced similar issue. It appears that the plate leaks only in one area – see picture. The engine has been sitting on my work bench for a few months after rebuild, hence is leaking even at cold temp. - I checked the plate on a mirror and it appears to be flat and the overall condition looks very good – no nicks nor bents or scratches at the sealing surface. - New o-ring and copper washer have been installed. - The M6x10 hex screws have been tighten to spec. - The crank opening measures 84.2mm, the taco plate’s o-ring surface measures 76mm and the o-ring is 4mm thick. It takes only a little bit of force to put the plate in place with mounted o-ring and it appears that plate is already touching the crank-case w/o torquing down the screws. Any ideas or suggestions? Thanks, Dragan |
draganc |
Dec 10 2010, 10:51 AM
@ Chris, I guess the 0.9mm would do the trick.
@realred914, that's a good idea with coloring the o-ring! I just order a new taco plate, o-ring and sealing washer and will post some pic with measurements of the new parts. Thanks again! Dragan |
Lo-Fi Version | Time is now: 10th June 2024 - 05:08 AM |
