Still running poorly, 914/6... |
Lawrence |
Apr 9 2003, 06:42 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
It warmed up a little yesterday, so I worked on the /6 when I got home from work.
Replaced two fuel filters, and remounted the pump, that seems to have come a bit loose. I had hoped that replacing fuel filters would clear up the running issue. No luck. The car runs poorly - under load/acceleration it hiccups, spits, backfires. Once I get it to a cruising speed, it's not too horrible. The plug wires ore OEM, and only have a couple thousand miles on them. I checked the cap and rotor, and they looked okay. I'll try the new coil from Summit tonight. Any thoughts or suggestions? -Rusty |
Gint |
Apr 9 2003, 07:25 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Refresh my memory...
What did you change that made it run like crap? Didn't you put a pertronix in it or something? I can't remember now. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:31 AM |
